Originally Posted By: mechtech2
There were/are lots of Porsche lifter designs.
I don't know what you have.
In older engines in days past, MMO was commonly used to clean things out [small passages in lifters were often helped].
And it worked.
I do not recommend MMO in the crankcase unless there is a known problem. And here, you do have a problem that may be attenuated with proper MMO use.
It is a far better solution than simply using a slightly thinner oil. BTW, I would not race around with it in the crankcase, either.
This sounds like the answer to the OP's question.
Here you have a real live mechanic who has apparently had some experience with these engines.
So, you might try MMO for a couple of thousand gently driven miles and see what happens.
Best case scenario, the problem is a clogged lifter and it's now fixed, with your having avoided what may turn out to be a very expensive guessing game with your current shop.
Worst case scenario, no harm is done, other than your having to change out a bunch of expensive Euro-spec oil to get rid of the MMO.
Your current shop is already into you for quite a few dollars and has yet to fix the problem with your engine, or even figure out what it actually is.
Before doing anything, I'd hit the Boxster boards and see what you can learn about your problem.
It may be that somebody else has had exactly the same problem, and has paid to have it found and fixed.
Also, a lifter problem related to debris can be intermittent. Been there and seen it.
