I converted my truck from an electric fan to a clutch fan to increase gas mileage. Well I had the bad idea of putting the new temp sensor in the radiator hose. Well it didn't seal and I lost some coolant. I then fixed it by putting it where it belongs in the radiator fins. Well I got air in the lines. I did the normal opened the cap and let the bubbles come out but that didn't solve it. So I bought a no spill radiator funnel. Put that on filled it up about a 1/4 of the way opened the bleeder bolts and revved the engine. Watched bubbles come out. Well I did this until bubbles stopped coming out. Took the truck for a test drive got about 8 miles and it started to over heat. So I just did it again and this time I didnt open the bleeder bolt.
Its an 03 frontier v6 N/a. Most of the time I am driving it is running a little bit cold in stop and go traffic.Then I get on the highway and that is usually when the over heating starts. It is very sporadic but once it over heats its hard to get it to cool down. Is there a trick to getting the air out that I don't know? I am leaving for work in a bit and if it over heats on the way I will put the clutch fan back in for the time being. I want to make sure the fan is not the issue.
BTW the fan swap I did has been done by many people with no overheating issues but its possible I made an error installing it.
