Originally Posted By: LeakySeals
Originally Posted By: jek
Any thoughts on going with a mobil ow40 or t6. i'm just throwing this out there that's all guys.just getting opinions that's all. perhaps the w30 is the ideal. i do here about t6 seeming to do well, but not sure on the na's.
Lot of subie enthusiasts swear by T6, probably turbo?
Yes, because turbo (and because racecar!). The NA models are different though-that is, they're easy on oil. The EJ22 and EJ25x (non-turbo) cars are spec'd for 5w-30, with a 7500mi oci. Some of the older EJ18 and EJ20 motor spec'd 10w-40 back in the day if I still remember right. I've seen at least one UOA on an older legacy where he ran whatever 5w-30 the dealer put in for that long, and while the TBN was shot by then, he was just fine.
IMHO, what you're running in your sig is just fine-it's cheap, it's good, and won't void your warranty. I've never heard of SoA voiding warranties for using oil that was the wrong grade (at least first hand), but they will void people that never change it-hold on to your receipts, and date when/how many miles when you do it. My friend of a friend leased a '07 Impreza 2.5 RS this way, and caused zero problems when he went to finally turn it in (bought a '09 Legacy GT afterward).
Even after the warranty ends, couldn't think of a good reason to run 5w-20. Maybe if you were a hardcore hyper-miler (buy something else) or lived in the great white north (buy a block heater), that's about it. Subaru engines will put up with lots of abuse and general stupidity-besides doing drop-clutch launches at 5000 rpm or NEVER rotating tires, there isn't an easy way to kill one.
