I do my own lube services on my semi. A relatively simple job. I like having a Fumoto drain valve in place of the drain plug so I can control or shut off drain if I need to. Filters (oil and fuel) are simple. Greasing the truck is a no brainer also. I guess I could have someone else do it, but I know that it is being done right and nothing is missed. I can inspect the entire underside of the truck, which is really important now with CSA 2010 regulations and such. I just don't trust any of the standard truck lube places to let me know about a problem underneath or even hit all the grease points properly. If it was just a matter of changing oil and filter on a car, then I might consider a lube shop. With the government breathing down trucking's collective back, I can't afford the least little slip up because some tech was having a bad day and didn't notice something. And I save money over what it would cost me at a truck lube place. The only other person I would trust under my truck doing this job is a full blown certified tech that knows how to look at every component under that rig.
If you can change oil and lube a standard pickup, you can do a semi. Like was stated earlier.... it is just a bigger job. But there is a lot of stuff under that chassis that needs looked at and checked. Without a firm understanding of what is going on under that truck, you really can't do the job properly.
