I want to replace the coolant in the wife's 07 Honda CRV. on most vehicles I prefer to drain as much coolant as I can, fill with distilled water, run for ten minutes and then repeat the process until the water drains out clear. i then fill with full strength coolant for half the total capacity. Then top off with distilled water. This ensures a proper 50-50 mixture. The Honda coolant and the Zerex asian coolant look to only be available in 50% strength. So, there is no way to get a 50-50 mixture using that stuff as there is always a quart or so of water left in the system after flushing with water. How do you guys handle this dilemma? Run less than a 50-50 mix or use something that you can buy full strength? If full strength, what are you guys running in your Hondas?
Thanks...
Thanks...
