Heard about this on the radio today. Thought it was pretty neat
idea.
Nissan's system takes the individual readout for each tire one step further -- it signals when the tire reaches the recommended pressure, no tire gauge needed.
The pressure sensor in each wheel communicates with the car's body-control computer. When air is added to a tire, the car's parking lights flash three times to let you know the system is active. (Note: The ignition has to at least be in the accessory position for the system to work.)
When the tire sensor reads that the proper pressure is reached, it briefly sounds the car horn. That's the signal to stop adding air. If the tire is overinflated, the car horn chirps three times -- a signal that some air should be let out. When the recommended pressure is reached, the horn chirps again.
http://www.shopautoweek.com/articles/201...ets-easier.html
idea.
