First generator
by daves87rs - 05/31/20 01:50 AM
New junk tool
by P10crew - 05/31/20 01:07 AM
tetraethyl lead additive
by painfx - 05/31/20 12:40 AM
Best handheld cordless vacuum?
by montero1 - 05/31/20 12:15 AM
2005ToyotaSolara3MZ-
FE coolant leak
by juca - 05/30/20 11:22 PM
I made a dually today. Carftsman LT1000
by ls1mike - 05/30/20 10:39 PM
New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
Oil Drain vs Extraction
by js1956 - 05/30/20 08:08 PM
Toro SR Won't Stop Running
by jkasch - 05/30/20 08:05 PM
Lexus RX350 Oil Filter Housing Question (with pic)
by CrackyWainwright - 05/30/20 07:57 PM
Oil Filter and Coolant Question
by maverickfhs - 05/30/20 07:33 PM
Second change on rebuilt LS
by KirklanC - 05/30/20 07:05 PM
Certified Used Toyota; 8 miles.
by simple_gifts - 05/30/20 05:47 PM
Motul Specific LL01-FE 5w-30 for BMW S55
by sharpmoney - 05/30/20 04:36 PM
Thinking of Buying Compressor
by Mr_Luke - 05/30/20 04:16 PM
juca, jrow96, Kotsos, sharpmoney, Dermented
71581 Registered Users
19 registered members (bachman, carlprop, Anduril, blufeb95, 92saturnsl2, AndyB, 1 invisible), 1,355 guests, and 41 spiders.
Topics306,070
Posts5,285,872
Members71,581
Another non-synthetic 0w-20 #2652771 06/13/12 02:23 AM
The Critic Offline OP
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9040510&contentId=7061133
I was on the Castrol website earlier and noticed that GTX SynBlend is being offered in a 0w-20. The MSDS was issued on 4/10 so I am guessing that this is a new product.
Obviously, 0w20 can be blended without needing to use mostly synthetic base stocks. So, buyers should not assume that all 0w-20s will always be full-synthetic.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Another non-synthetic 0w-20 [Re: The Critic] #2652778 06/13/12 03:21 AM
I
Indydriver Offline
I
Yes, Honda has had house brands in both full syn and blend 0W-20 since they introduced their COP made oils.
That's slicing the market pretty thin, isn't it?
Your thread begs the question for 0W-20 oil users (I now have two late model OE 0W-20 engines): Is saving a couple of bucks a quart ENOUGH for you to use a lower quality oil in your baby?
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 85,000 M1
2007 Tahoe 155,000 M1
Re: Another non-synthetic 0w-20 [Re: Indydriver] #2652785 06/13/12 03:45 AM
As of now, Honda/CP and Valvoline Durablend were the only ones with a non-syn 0w-20.
Now Castrol has entered the market in that area.
Re: Another non-synthetic 0w-20 [Re: Indydriver] #2652816 06/13/12 06:02 AM
H
Hokiefyd Offline
H
Castrol already offers a 0W-20 in their Edge line; I've seen it at Advance Auto. I didn't notice the price; it likely carries a huge premium there. If Castrol can get this GTX 0W-20 in a jug on the shelves at major discount retailers, for $20/jug, then it should be a great value. "Synthetic" and "semi-synthetic" are largely marketing terms anyway, especially because we don't know the actual blended ratios of the base stocks.
Re: Another non-synthetic 0w-20 [Re: Hokiefyd] #2652832 06/13/12 06:47 AM
I
Indydriver Offline
I
And this gets to the root of my question. My new Toyota V6 comes with TGMO full syn 0W-20 along with a 10,000 mile OCI. I wonder if Toyota says the design and performance differences beyween full syn and semi-blends don't matter. Note that Toyota specifically advises reducing the OCI in HALF when 5W-20 (presumably conventional) is used. I have no doubt that the cheapest 0W-20 available will find it's way into these engines and I wonder if Toyota engineers left enough safety margin in the performance of blends to go the full OCI.
IMHO, 10,000 miles is pushing the envelope for any oil when designers HAVE NO CLUE how the vehicle is driven every day. Now, they are reducing the margin for shear and viscosity deterioration. Some one is going to take this too far.
Re: Another non-synthetic 0w-20 [Re: The Critic] #2652881 06/13/12 07:42 AM
B
buster Offline
B
I'm not so sure about this. You do need mostly syn base oils.
From Mobil.com FAQ:
10. Are all 0W-20 viscosity oils synthetics? Yes. The 0W-20 viscosity grade requires synthetic-base oils to meet low-temperature performance standards. >>back
Most if not all 0w20's are synthetic. I am not sure if I believe you can make a 0w20 blend of mostly GrpII+.
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Another non-synthetic 0w-20 [Re: Indydriver] #2652894 06/13/12 08:02 AM
H
Hokiefyd Offline
H
Right now, the "cheapest 0W-20 available" is Mobil 1 AFE 0W-20, if by cheapest you mean most inexpensive. Now, if by cheapest you mean the poorest quality, I revert back to my belief that the differences in "synthetic" and "semi-synthetic" are largely in marketing, and anything meeting the 0W-20 specification is going to have very good performance properties.
And for another data point, Hondas are out there doing 10k mile OCIs on conventional 5W-20. I'd say that even the worst quality 0W-20 out there will be sufficient for Toyota's 10k mile OCIs.
Re: Another non-synthetic 0w-20 [Re: The Critic] #2652923 06/13/12 08:48 AM
A
ARCOgraphite Offline
A
Indydriver:
ILSAC GF-5 "conventional" must beat a PAO synthethic standard test oil in fuel mileage and must also be OLM capable and pass TEOST deposit test (for turbo and ring area deposits) in the heavier grades. So what is compromised? And what would be the "real" higher group(iv+v)synthetic you are buying that's not a specialty or racing product? Amsoil Signature? I cant think of ANY major player currently that advertises as "fully synthtetic" that uses only group iv and higher.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Another non-synthetic 0w-20 [Re: The Critic] #2652935 06/13/12 09:08 AM
DrDusty86 Offline
ARCO- RP AZO....
Re: Another non-synthetic 0w-20 [Re: The Critic] #2653015 06/13/12 11:04 AM
A
A
I think that's a nyet on the RP for their street oils.
Re: Another non-synthetic 0w-20 [Re: ARCOgraphite] #2653037 06/13/12 11:42 AM
I
Indydriver Offline
I
Originally Posted By: ARCOgraphite
Indydriver:
Are you saying that you believe there is no performance difference in the 0W-20 viscosity between an oil marketed as "full synthetic" and one priced two bucks lower labeled "synthetic blend" (within brand)?
Re: Another non-synthetic 0w-20 [Re: The Critic] #2653050 06/13/12 11:56 AM
A
addyguy Offline
A
Nice to see another option in the 0W-20 grade.
Castrol now has 3 0W-20's - they have Edge 0W-20, Edge w/SPT (black bottle) 0W-20, and Syntec Blend 0W-20.
However, I doubt we will ever see it up here, we still only have a tiny bit of Edge 0W-20 up here, no mainstream stores carry it.
2010 Kia Soul 2U - 2.0L I-4, auto; 153k miles.
Castrol GTX 5W-20; Motomaster MPH 9688
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Another non-synthetic 0w-20 [Re: Indydriver] #2653948 06/14/12 08:45 AM
A
A
Indydriver:
Maybe a marginal cold crank improvement and hopefully a small VI improvement. Otherwise they meet the same spec.
Re: Another non-synthetic 0w-20 [Re: The Critic] #2653967 06/14/12 09:02 AM
05Blazer Offline
Hokie
"I'd say that even the worst quality 0W-20 out there will be sufficient for Toyota's 10k mile OCIs" (Hokiefyd).
I bet that Peak 0W20 wouldn't make it to a 10kOCI without some significant wear. Have you seen the VOA on that stuff, yuck!
2014 Lexus F-Sport 3.5L HO
Mobil1 0W20 OEM filter
11 Honda Pilot EX 4WD 3.5L 70k
Penn Plat 0W20 OEM filter
Re: Another non-synthetic 0w-20 [Re: The Critic] #2654580 06/14/12 08:19 PM
O
ottotheclown Offline
O
Me, I face a $80 bill for Subaru syn 0-20 for my 2012 Forester at the stealer. Guess what I am going to do???
ottotheclown
