Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0; 10w-30/5w-40 mix 8.6k miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
leafuntec, wolf777, Smittyzzz, JimBobSeeker, Joey737
69902 Registered Users
61 registered members (2010Civic, 65convertible, Amkeer, Aichiguy, 77GrandPrix, 2015_PSD, 5 invisible), 889 guests, and 17 spiders.
Topics297,573
Posts5,118,294
Members69,902
Most Online3,589
Nov 2nd, 2019
Honda Dual-Pump Fluid vs. Acura AWD fluid #2646833 06/06/12 02:08 PM
V
vinu_neuro Offline OP
V
This is the same stuff right? The Acura p/n just has an extra A at the end of it. Just want to be sure since my application is unique and Honda and Acura use different types of diffs.
2008 Acura TL
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: vinu_neuro] #2646841 06/06/12 02:18 PM
M
Mau Offline
M
No it isn't.
17 MB C43 AMG - Pennzoil Platinum Euro 5w40
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: vinu_neuro] #2646854 06/06/12 02:31 PM
V
V
Are you still on Z1 in your RDX or have you gone to DPSF? If you're on DPSF did you notice any difference?
2008 Acura TL
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: vinu_neuro] #2646857 06/06/12 02:32 PM
M
Mau Offline
M
Z1 is still in the rear diff of the RDX but DW-1 in the transmission.
I'm going to drop the RDX off at the dealership for the rear diff, don't feel like getting under there for 80 bucks.
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: vinu_neuro] #2646861 06/06/12 02:37 PM
H
Hokiefyd Offline
H
Is Honda specifying the DPF-II now in differentials once requiring Z1?
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: Hokiefyd] #2646874 06/06/12 02:44 PM
V
V
Z1 is no longer produced. Any vehicle with SH-AWD has now been moved to DPSF (Acura AWD Fluid) for the rear diff. Rear diff is super easy, not worth $80.
In SH-AWD vehicles Z1 used to be used in the auto trans as well as rear diff. The specification has diverged now, DW-1 in the trans, DPSF in the diff.
To answer my own question I found a thread on mdxers. Someone bought Honda Dual-Pump Fluid II (DPSF II?) as well as Acura AWD Fluid (DPSF) to find out the same thing. Apparently they look the same but smell different. So I guess they're not the same.
2008 Acura TL
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: vinu_neuro] #2646963 06/06/12 05:13 PM
H
Hokiefyd Offline
H
What are you referring to as DPSF? Dual Pump System Fluid? I've only known it as DPF or DPF-II, or Dual Pump Fluid (version 1 or 2). I'm not saying I'm right and you're wrong; I was just confused about the initialism.
Re: Honda Dual-Pump Fluid vs. Acura AWD fluid [Re: vinu_neuro] #2647181 06/06/12 09:35 PM
V
V
It has always been DPSF. Dual-Pump Sytem Fluid. I'm guessing Honda's are using DPSF II and Acura is using the previous fluid in SH-AWD diffs. First image is an excerpt from a CR-V tsb.
2008 Acura TL
