The results were somewhat disappointing.
First, VOA on D1 LE:
Al 2
Si 5
Na 5
Mg 762
Ca 1980
P 773
Zn 929
Mo 44
B 113
vis 12.0
TAN 3.54
TBN 9.6 (D4739)
Next D1 LE Castrol SLX Prof LE
12600mi 9000mi 10000mi
Fe 152 83 94
Cr 6 4 5
Pb 3 1 3
Cu 18 12 20
Al 26 27 33
Si 6 4 6
Na 3 5 7
K 20 31 51
Mg 674 11 10
Ca 2160 1960 2509
P 876 768 910
Zn 1020 859 815
Mo 45 1 B 80
vis 11.7 10.0 11.6
soot 0.8% 0.9% 0.6%
TAN 8.07 ??? 4.83
TBN 2.3 1.5 1.5
All not listed either 0, 1 or negative.
During the middle of the D1 LE the EGR cooler failed and was replaced, evidently no coolant leak (except the K results??).
Conclusion: I ran the D1 LE too long. If I run it the prescribed 10K mi TBN/TAN will be better. Possibly the relatively high VOA TAN relates to esters Mobil tech line confirms are in the D1. Possibly the high Fe number relates to ester "washout" from the first OCI on D1.
This is obviously a high Fe/Al excreting engine. I haven't gone on the BMW forums to confirm that however.
This next OCI I will change when the indicator tells me to and not delay 2600 miles.
Charlie
Al 2
Si 5
Na 5
Mg 762
Ca 1980
P 773
Zn 929
Mo 44
B 113
vis 12.0
TAN 3.54
TBN 9.6 (D4739)
Fe 152 83 94
Cr 6 4 5
Pb 3 1 3
Cu 18 12 20
Al 26 27 33
Si 6 4 6
Na 3 5 7
K 20 31 51
Mg 674 11 10
Ca 2160 1960 2509
P 876 768 910
Zn 1020 859 815
Mo 45 1 B 80
vis 11.7 10.0 11.6
soot 0.8% 0.9% 0.6%
TAN 8.07 ??? 4.83
TBN 2.3 1.5 1.5
Charlie
