I am waiting for a brrand new distributer to arrive to my place that i just purchased a few days ago online and the guy that built the distributer told me to run a good qaulity cap and rotor with brass contacts on it for best performance on fuel mileage. I have been trying to determine who makes the best ignition replacement parts....
There is alot of them autozone carrys the duralast brand wich i believe is made by wells. Napa sells there Echlin line. advanced auto and oreilly auto parts sells Borg warner select ignition parts. I do not know for sure but i have been told that standard motor products supplys car quest with there premium line ignition parts. Wich one of these is the best choice as far as a well built cap and rotor thats going to last and put out good performance?
The distributer is a mopar performance electronic distributer thats going into a 300 horse power 360 magnum in a 1991 dodge ram. I have tried the borg warner select parts before but not there caps and rotors i tried there voltage regulator and there coil, the coil has held up but i kept frying the voltage regulator... I then found an old WElls voltage regulator in my old mans garage that said made in usa right on it, bolted the wells voltage regulator on and never had another problem with frying voltage regulators... So i dont know that i trust the borg warner select brand to be the best. I have ran echlin stuff before but it was so long ago and i couldnt tell ya if echlin ignition parts are good or not, but i have heard that echlin parts are real good.
I have also heard that standard motor products are really good too. I am currntly running an ignition module that i bought from car quest and its there premium line ignition module so i dont know what brand car quest sells but if car quest sells standard motor products then thats what my ignition module is. I have not had any problems with the ignition module i also bought my ballast resistor from car quest in there premium line and i have not had any problems with it ether.
Anyways i am just trying to learn more about ignition parts and wich company is good and wich one is not so good. Also looking at replacing my spark plug wires any reccomendation on a good qaulity set of 8mm plug wires? The borg warner select wires have a life time warranty so does the napa beldin but i was thinking of getting a set of wires from mallory or crane cams or msd or taylor something like that... Anyways school me on replacement igntion parts whats good and whats mid grade and whats garbage? Thanks
