hehe sorrie if im being a pain in this forum but i did a little more hw and i got a summary of what most people did for auto rx
----> im just cautious of what my car has in its engine...using this product is a big step for me
"Auto-Rx works on ratio's for engines it is 2 ounces per quart of oil (any type oil ) for engines over 100,000 miles you need to clean that engine two different times ( you don't put more than two ounces of Auto-Rx in each quart of oil to clean as you just waste additional product and get no additional benefit ) Auto-Rx turns accumulated "Crud" into liquid form so nothing can stop up oil screen , piston port, or wrist pin. Drive 500 miles if you use "Dino" Oil or 750 Miles if you use "Synthetic" than change out your oil and filter. Drive 750 miles to 1000 Miles with just new oil and clean filter, when you get those miles on add second bottle of Auto-Rx and repeat procedure. Your done.Remember Auto-Rx works while you drive, over miles safely and cleansing your engine every mile. "
i have about 1000 miles till my next oil change. i might as well put new oil and a cheap supertech filter in now and do my first application of auto rx at 525 miles with 2oz per qt...
after i will replace the oil and filter with supertech filter and run it for about 1k miles...maybe less
then i will add another treatment with new oil and filter for i dont know how many miles..with 3 oz per qt of auto rx...and then hopefully everythign will be good..
then last a final top off of regular oil and a quality bosch oil filter.
