I have the transmission from my Lawn-Boy 10330 out and on the bench. I've cleaned the entire thing out and need to re-grease it. It calls for 2.5 to 3.0 fl oz of #2 grease. It doesn't say WHERE to grease it in the service manual. It simply says to apply the grease and install the cover.
I hate this type of design. Extra lubricant does no good; it will just accumulate on the case wall and never see a gear. To me, adding JUST enough lubricant to coat the gears, and not have any extra to fling off, is perfect. But 2-3 fl oz is over 1/4 cup of grease. To me, that's a ton of extra grease on the case walls not doing anything.
What do you guys do when you have to grease something like this? Just enough for the gears to run on? I'd much rather the gears ride in a bath of 90W oil and have to mess with Permatex sealant on the case cover than try and properly grease these types of units.
All suggestions are appreciated!
