2018 Ram 2500 with 21k miles. Delo 400 XSP 5w40
by bigbadbowtie - 02/27/20 11:08 AM
For those always asking about tiny Computers
by jayjr1105 - 02/27/20 11:05 AM
Original 2016 VW Passat cabin filter
by Vaca - 02/27/20 11:02 AM
Original 2016 VW Passat air filter
by Vaca - 02/27/20 10:54 AM
Napa Exceptional Customer Service
by Fitz98 - 02/27/20 10:38 AM
Astra 400 ?
by WyrTwister - 02/27/20 09:58 AM
Will thinner oil damage anything when it is burned?
by Fordiesel69 - 02/27/20 09:38 AM
Old news for Hyundai/Kia?
by Farnsworth - 02/27/20 09:33 AM
Looking for AA 25% off coupon code.
by JustChuck - 02/27/20 09:17 AM
New to the LS460 and The World Of Lexus. Questions!
by gr8gatzby - 02/27/20 08:41 AM
New old guy back.
by BJD2020 - 02/27/20 07:45 AM
Help me Decide
by Gebo - 02/27/20 07:36 AM
FWD - Death traps with miss matched tires.
by Fordiesel69 - 02/27/20 07:13 AM
Napa Gold Sale
by Toto - 02/27/20 06:52 AM
2016 or 17 Honda CR-V
by Loogie - 02/27/20 05:20 AM
RIP Clive Cussler
by PimTac - 02/27/20 04:48 AM
Pirelli Cinturato P7 Allseason PLUS "II"
by Char Baby - 02/27/20 03:31 AM
CCI clean .22 ammo - polymer coated HV
by Shannow - 02/27/20 03:23 AM
5w-20 vs 5w-30
by joel95ex - 02/26/20 10:59 PM
Scotts994Runner, Bu33leGutz, splitthebreak, shadango, JimNastic316
70808 Registered Users
102 registered members (Alfred_B, 77GrandPrix, 1978elcamino, 2009Edge, ABerns, ArrestMeRedZ, 7 invisible), 2,104 guests, and 15 spiders.
Topics301,989
Posts5,206,890
Members70,808
Page 1 of 3 1 2 3
ATF as an engine flush #263558 02/10/03 02:38 PM
P
Patman Offline OP
Global Moderator
Global Moderator
P
I did a search, and even though I know it's been discussed here I couldn't find this topic.
What exactly are the problems with running ATF as an engine flush?
Re: ATF as an engine flush #263559 02/10/03 03:49 PM
B
Bill Plock Offline
B
On a Diesel related forum I read several people report good results using ATF to free up sticking lifters. If I remeber right they suggested adding a quart of ATF and driving for about 100 miles... then change oil and filter. (Personaly I have never tried this).
[ February 11, 2003, 07:51 AM: Message edited by: Bill Plock ]
Re: ATF as an engine flush #263560 02/10/03 03:50 PM
J
jjbula Offline
J
I've been told ATF is a near 0w20 oil. Besides being thin it is no better at flushing than motor oil.
BTW, I just finished running Neutra in my V6 Camry for 100 miles. Within 10 secs of start the noise I thought was the accessory drive belt went away. I think the gears under the cam cover were making the noise. The noise started at 5K miles on Valvoline synpower and didn't go away when I switched to Schaeffer blend (before the neutra).
After draining the neutra (and filling with Schaeffer Blend) the noise is still gone. I'm convinced that Neutra is a useful product.
[ February 11, 2003, 07:52 AM: Message edited by: jjbula ]
Re: ATF as an engine flush #263561 02/10/03 05:43 PM
M
metroplex Online Content
Online Content
M
ATF is RICH in detergents so its definitely useful in flushing out crud in your engine.
jjbula: Neutra may be a good product, but please check out the facts on ATF before slamming it.
Re: ATF as an engine flush #263562 02/10/03 06:58 PM
J
jason07-1zzfe Offline
J
ATF analysis I have seen actually show less detergents than most motor oils. I don't get it.
Re: ATF as an engine flush #263563 02/10/03 07:58 PM
D C Anderson Offline
I was in a training session for industrial lubrication by a retired Mobil Rep. As all lubrication training sessions go everybody wants to talk about their cars. The Mobil rep said he had been using ATF for a flush just before a oil change for years. I have tried it myself for the last 8 years and I'm a firm believer. I don't do it every oil change, only when I see the new oil I have just put in become dirty within the first 1000 miles or so. I make a mental note to flush at the next oil change using ATF. The most I have added is 1/2 quart and driven 100 miles or less then change the oil. The used oil comes out jet black and the new oil I put in stays clean for several 1000 miles before changing color. I'm a 5000 mile oil changer using dino oils. On my old truck at 160K, everything looks clean of what I can see looking through the oil fill cap. Believe it or not!
Re: ATF as an engine flush #263564 02/11/03 08:44 AM
P
Patman Offline OP
Global Moderator
Global Moderator
P
I guess I can't see using something like ATF as a cheap flush when Neutra is only like $2 a bottle and it's definitely safe in the oil, and does not harm it's lubricating qualities (Bob proved that when he ran a full 12oz bottle in his oil for 4000 miles and did analysis)
When you do that oil change after running the ATF, there will still be a little bit of that ATF in the engine, so your next oil change will be affected too.
Re: ATF as an engine flush #263565 02/10/03 10:07 PM
J
jjbula Offline
J
Point taken. Now tell me, what is in ATF that is not in motor oil? Are some ingredients in higher concentrations because it doesn't need to deal with combustion byproducts?
Re: ATF as an engine flush #263566 02/11/03 09:22 AM
R
RB Shannon Offline
R
I was under the impression that detergent's were acting as an enveloping type additive keeping insoluable organic matter from forming into larger pieces, or onto surfaces, and that the ester's in RX and neutra actually helped to lift up deposit's and put them into solution.
Re: ATF as an engine flush #263567 02/11/03 01:25 PM
N
nick778 Offline
N
From what I read from previous posts, ATF isn't ashless which creates its own deposits. However, I too would be interested in what is in (or isn't in) ATF that makes it a good or bad idea to use it as a flush cleaner.
Re: ATF as an engine flush #263568 02/11/03 02:13 PM
cryptokid Offline
i believe its incredibly high ammounts of detergents.
i know my father said he would use atf as a hand cleaner after dealing with ultra heavy greases, the kind of grease hand cleaner is scared of:)
my uncle mike commented that he did this as well, being mechanic for 30 years he said atf is a wonderfull detergent cleaner, rivaling the aewsome power of diesel. only atf dont make your skin burn like diesel does. put it this way. when i rebuilt my subaru engine, instead of scrubbing the internal parts to remove sludge, (pan, heads, lifters valve covers etc) i just soaked them in atf for a week. after a week, i swished around the atf with my hand and then pulled the parts out, which were shiny clean. the solid sludge perfiously required a screwsriver to chip away at.
i just dont know about running it in a engine though. i had an idea once to full up the engine with atf, remove the spark plugs and tow the car around the neighborhood for a couple minutes.a and then let it sit and soak for a week. i may still end up trying this idea.
atf is certainly NOT designed to do what we are talking about. so there will never be any guratintee's it will work as expected, or not hurt anything. im sure the shear strength of atf isnt designed to be in an engine. just for the hell of it, come next oil change im going to run 100% atf through my engine, at idle, for 5 minutes, then let it sit for a week and soak in. after a week i will run it again for 5 minutes, and then drain the oil. well see what happens. if it blows, i dont care honestly.
Re: ATF as an engine flush #263569 02/11/03 03:38 PM
Spector Offline
Previous Post stated
"just for the hell of it, come next oil change im going to run 100% atf through my engine, at idle, for 5 minutes, then let it sit for a week and soak in. after a week i will run it again for 5 minutes, and then drain the oil. well see what happens. if it blows, i dont care honestly."
Look forward to the results. What are you going to place the ATF in that you don't care if it blows?
Re: ATF as an engine flush #263570 02/11/03 04:15 PM
cryptokid Offline
heh, a porsche engine thats at the end of its life. its pissed me off enough times that ill get satisfaction if it does get wrecked. i hate that stinky thing.
Re: ATF as an engine flush #263571 02/11/03 05:20 PM
T
Tommy Offline
T
I have wondering about this as well and have done a bit of looking around - it seems that sulphur is indeed being used in ATF - this would be one good reason not to use it in an engine! Another good reason might be this....have a look at this blurb that I copied from an ATF MSDS:
Products based upon refined liquid mineral oil of various viscosities derived from high boiling point fractions of petroleum, and which may contain additives such as:- anti-oxidant, detergency, dispersancy, organic anti-wear, foam suppressant of the wax or silicone types, organic sulphur, chlorine and phosphorus, organic polymers, solid lubricants, organo-zinc antiwear additives.
Here is a page that might interest you - it is a spec. sheet for an ATF product that shows concentrations of calcium, zinc, phosphorus, barium and yes, sulphur!
http://www.westpenn.com/sheets/mopar.html
Re: ATF as an engine flush #263572 02/11/03 09:06 PM
N
nick778 Offline
N
With some synthetic xx-30w oils being at the low end of the 30w range, i'm still a little unclear on what, if any, harm mixing 1 qt ATF with 4qts of oil and running the engine for 30 minutes as a flush would be....especially if there is little or no problem with the additives.
Page 1 of 3 1 2 3
