Originally Posted By: lemonade
Originally Posted By: Gokhan
Originally Posted By: mechtech2
OK then. 0 Zero in HTHS engine oil terms is not water's viscosity, but more of an absolute zero viscosity.
A total vacuum would be a zero HTHS, for instance.
[I don't think those who set the parameters had superfluids or total vacuum engine operation in mind}
Yes, water has nonzero viscosity, and so do all normal fluids.
Not sure what you mean by "0 Zero in HTHS engine-oil terms" but viscosity (dynamic as in HTHS or kinematic) is not just an engine-oil term but a more general physical quantity used for all fluids. Also, as you know, of course, 0W in SAE 0W-x grades is not a measure of viscosity but only some cold-temperature viscosity-grade specification. NLGI also uses 0, 00, 000, etc. for the thinner grease grades.
The only fluids in nature that have zero viscosity are superfluids. In fact, the only known superfluid is liquid helium near the absolute zero temperature, less than 2 degrees kelvin above absolute zero for the abundant He-4 isotope of helium. It becomes a normal fluid at higher temperatures and boils around 4 degrees kelvin above absolute zero. Less abundant He-3 isotope also exhibits superfluidity but at even much lower temperatures and due to a different physical mechanism.
I guess you can talk about the viscosity of vacuum if you really want to but since vacuum means absence of matter, it's not really a fluid, and it would be hard to define and/or devise a method to measure its viscosity. It would also strongly depend on the vacuum pressure of course.
Unlike a superfluid, the viscosity of vacuum would also never be exactly zero. If you consider the ideal case of an exact vacuum, then you can't talk about viscosity because there is no fluid (matter). On the other hand, superfluid helium has absolute zero viscosity because of a subtle quantum mechanism. It can do a lot of interesting things. For example if you put superfluid helium in a cup, it creeps up along the inside wall and then down the outside wall until the cup is completely empty. See this picture of superfluid helium in a cup:
So, if you could refrigerate your garage to near absolute-zero temperature and put superfluid helium in your engine, thanks to having absolute zero viscosity, it would creep up your dipstick tube and you would find it all on the floor when you came back in the evening.
Remind me of quantum class, He, with 2 proton, 2 neutron and 2 electron, He-4 is a boson, hence subject to Bose-einstein statistics, and boson are not subject to Pauli exclusion principle, so there's no limit to the number of bosons that may be in the same quantum state, so we have superfluid. oh my god, can't believe i still remember these.
Oh, about He-4 flow up the dipstick thing, this is called "creeping flim", i think... don't remember exactly.
I have something to add about liquid He though, if one tries to measure the viscosity by, for example, measuring the drag on a metal plate as it is passed over the surface of the liquid, the result is about the same as the one we would expect from a normal liquid, even at temperatuire below the lambda point. Inother word, there appears to be a contradiction here. Some scientist later proposed a solution stating that liquid He below lambda point is part superfluid and part normal, with increasing portion of superfluid approaching 0Kelvin once it drop below lambda point.
Way off topic.... sorry
Ah, another physicist here! Cool!
Good knowledge by the way.
