I fixed the head gasket on my 1999 Buick Century last year but now it's not sealing properly. Either I didn't clean it good enough or it was warped. The head bolts were also replaced.
I'm going to fix it again. Last time, I used Fel-Pro PermaDry but this time, I'm going to use the PermaTorque. They don't cost much more and they look better.
This time, I'm going to take the cylinder heads to a machine shop to make sure they're perfectly flat.
What should I use to clean the mating surfaces? The engine block is cast iron but the cylinder heads are aluminum.
