Originally Posted By: afoulk
I think these engines have problems with high oil temps if they are driven on the track, at least in the 370z's. That may be where the heavier oil recommendation comes from
The problem is that the heavier oil temperatures cause the engine to go into limp mode sooner. The problem is oil cooling, rather than a viscosity issue. A 40 might "hold up" better to heat than a 30, but the 40 will get hotter. Fix the temperature issue first, then play with viscosity if need be.
I just use PYB 5w-30 without issues. For the question about sodium add pack, I believe the Valvoline syn has that. It's good to know this oil did well. The NAPA Full Synthetic (Valvoline) is under $25 for 5L up here right now at NAPA, while Walmart's selling it on "special" for like $43!
