Weather man say today is sunny and no rains until 2 more day, so I take my mustang to work, got off work, and heavy rains pour out, my cold air intake is on the fender and my inner fender shield is back order for 2 week, I like this is no good, but I have to go home, the road is wet and i drive really slow, after 4 min I can feel the filter is soat with water cause the tires splat water into the filter, i saw a little smoke and car is running rough, I made home and turn off the car, look at the filter and it soak with water
take off the cold air intake and water and found water in it, not driping out but you can tell water in it. so I beleive my engine is suck some water into the intake and burn off. Should I change the oil and filter ( its only 30 miles oil
). I will drive the camaro until i install the inner fender shield.
