oiltard
Thread starter
Prompt response from Blackstone. I'm kind of buying their "it costs more because service is better" argument, but that's a discussion for another thread.
Originally Posted By: Blackstone
Happy to help in any way I can. We use the Cleveland Open Cup method for determining flashpoint. Normally a low flashpoint is caused by fuel or a solvent of some sort, but that's not likely in your ATF. There is margin of error, as is always the case when humans are doing the tests, but it's quite small when it comes to flashpoint. It's possible that a number was entered wrong, so I'll see if there's enough sample to redo the flashpoint test and let you know. As for the viscosity, you're sample was normal compared to our benchmark for DW1 ATF. Viscosities tend to have a range to them that's normal as opposed to one number that each sample should adhere to. As long as it's within that range, we consider it normal. Have a great day.
