picked up a 2006 gmc 2500hd with the 8.1L.
It has an oil cooler and one of the lines from the block to oil cooler is seeping oil at the factory crimp. I am probably going to replace the lines with stainless braided AN hose and a new cooler.
but my question is, when i do an oil change does the oil drain down from the oil cooler which is mounted up in front of the radiator? And when i start the engine how long do you think it will take for oil to travel up and back from the oil cooler? This will be relevant when i get around to replacing the oil cooler lines and the cooler. I'm worried about lack of oil to crank during start up.
the lubrication path as listed in my service manual is this:
- oil from pan into oil pump
- from pump to oil filter outlet in engine block
- thru oil filter back into engine block
- out to oil cooler through outlet port in block right next to oil filter
- thru oil cooler at radiator and back to cooler inlet right next to outlet at oil filter
- now oil goes to crankshaft main bearings and up to lifter gallery, oil pressure sender, and cam bearings.
