I'm adding OP and OT gauges/senders to my Toyotas. This is not a crtical racing application, I just want to play around with different oil viscosities. I want to use electric senders so I don't have an oil tube running into the car.
The Sunpro has pretty cheap senders ($24 for both) and a tri-gauge cluster for around $25, so I can get the whole thing for around $50. I'm concerned about the quality and accuracy of these parts though. I've read a few reviews where people reported the senders broke off when trying to install, and that they seemed cheaply made. Still, if these would do the job, it's probably fine for my limited oil viscosity testing purposes.
The Auto Meter stuff looks like a higher quality product and the gauges that I've found look cool, but will exceed $100 for everything I need. That's fine, but not really necessary if the Sunpro kit will do the job.
The Equus gauges look alright and are priced right in between the Sunpro and Auto Meter. Anyone have any experience with them?
I was also looking at the Summit Racing brand of gauges, which are also reasonable priced, but not sure about their quality/accuracy. I've also only been able to find water temp and oil pressure gauge kits, but I assume I could use a Summit oil temp sender with the water temp gauge and it would still work.
I'm also assuming that I need to use the same brand sending units as I select for the gauges for compatibility reasons, but if they are cross-compatible, I'm not sure how to tell what would work together. Anyone know what to look for to determine compatibility between senders and gauges, or just stick to the same brand of everything to be safe?
Thanks for any help on this.
