Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Ericbrooks, Japanese, lordcheeto, WondrousBread, slickoo9
66672 Registered Users
33 registered members (CB900F2, 92saturnsl2, bmod305, 53' Stude, 19VWJettaS6speed, bbhero, 5 invisible), 862 guests, and 47 spiders.
Topics295,047
Posts4,926,782
Members66,672
Most Online2,553
Oct 27th, 2018
Valvoline DOT 3/4 "synthetic brake fluid? Possible #2566812
03/13/12 09:06 PM
03/13/12 09:06 PM
chicago, Illinois
antiqueshell Offline OP
chicago, Illinois
Just was checking out the Valvoline site and they have a product called Synthetic DOT 3/4 Brake fluid.
I was always led to believe that the only synthetic DOT was silicone DOT 5.
Is the Valvoline product I mention compatible with mineral based DOT 3 and 4?
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2566819
03/13/12 09:14 PM
03/13/12 09:14 PM
Austin, Texas
Brons2 Offline
Brons2  Offline
Austin, Texas
There is also an unofficial DOT5.1, which is silicone level performance but with a conventional fluid.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2566820
03/13/12 09:15 PM
03/13/12 09:15 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Its a play on what synthetic means. It has the same composition as any other OTC DOT 3/4 brake fluid.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: Colt45ws] #2566827
03/13/12 09:17 PM
03/13/12 09:17 PM
Watkins Glen, NY USA
ffracer Offline
ffracer  Offline
I have used it for years and it has better cold weather properties than just DOT3 brake fluid. the brake and clutch pedals are more responsive and consistent in the cold than regular DOT3. Multiple cars and very obvious.
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2566842
03/13/12 09:26 PM
03/13/12 09:26 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Brake fluid is a glycol, IIRC. Likely they are all synthesized.
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2566861
03/13/12 09:45 PM
03/13/12 09:45 PM
Florida, USA
Towncivilian Offline
Florida, USA
Yes, from what I've read here all brake fluid is synthetic. If it's touted on the bottle, it's just a marketing buzzword. DOT 3/4/5.1 are all interchangeable as well (but not DOT5 which is silicone based!), and each has higher minimum wet and dry boiling points than the previous.
Wet boiling point refers to fluid that is 3.7% water by volume.
Code:
Dry boiling point:Wet boiling point:
DOT3:205 C (401 F)140 C (284 F)
DOT4:230 C (446 F)155 C (311 F)
DOT5:260 C (500 F)180 C (356 F)
DOT5.1:270 C (518 F)190 C (374 F)
I run the mentioned Valvoline DOT3/4 brake fluid in my Pathfinder with no problems.
2001.5 Pathfinder SE 3.5L A/T 2WD - ML NG 5W-30/PL14610
2007 Altima S - PU 5W-30/M1-110
2009 G5 - PU 5W-30/XG9018
2012 G37 S - ST 5W-30/PL14612
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2567115
03/14/12 08:12 AM
03/14/12 08:12 AM
New England
Jarlaxle Offline
Jarlaxle  Offline
New England
Actually, silicone & glycol fluid can be mixed...no problem, but you lose the benefits of silicone brake fluid.
1979 Coupe de Ville, 542 stroker, winter storage frown
2011 Crown Vic P71, 5W-20 Super Tech, Super Tech
2011 Sportster 883, winter storage frown
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2567120
03/14/12 08:17 AM
03/14/12 08:17 AM
Rochester, NY
rslifkin Offline
rslifkin  Offline
Rochester, NY
Not all systems have seals and lines that can tolerate the silicone fluid, IIRC.
1998 Jeep Grand Cherokee 5.9 Limited with lots of mods (225k miles, bought with 100k in 1/2010)
Rotella T6 @ 6k OCI
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2567243
03/14/12 10:42 AM
03/14/12 10:42 AM
Washington St.
Ken2 Offline
Ken2  Offline
Washington St.
There is a minor chemical difference between the different grades of polyether glycol brake fluid to give it the various wet boiling temperatures, usually the addition of a borate compound. I don't know about Valvoline's labeling of this brake fluid as DOT3 and DOT4 except for marketing reasons. There are a very few brake systems that are designed for DOT3 and the rubber-like materials cannot tolerate the chemicals in DOT4 fluid. Maybe Valvoline found a way around this???
As described above, there is no natural brake fluid and all are synthetic. Putting "synthetic" on the label is just marketing hype.
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2567398
03/14/12 01:16 PM
03/14/12 01:16 PM
WatUpDoc
ltslimjim Offline
ltslimjim  Offline
WatUpDoc
Whatever happened to Valvoline's SynPower Dot 4 synthetic? I've 'heard' of it but never used it. confused ???
Same as their Dot 3/4 synthetic that is regularly available? shrug
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #2567638
03/14/12 05:24 PM
03/14/12 05:24 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
All brake fluid is synthetic.
The DOT5 has SILICONE .
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: ltslimjim] #2569721
03/16/12 02:19 PM
03/16/12 02:19 PM
Florida
artificialist Offline
Florida
They replaced the gold colored "Synpower" containers with the white "DOT3/DOT4" containers.
Either way, it was made to replace DOT3 or DOT4 fluid.
2010 Lancer Ralliart Sportback
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: antiqueshell] #4468231
07/23/17 04:48 PM
07/23/17 04:48 PM
WA, USA, Tacoma
capsicum Offline
capsicum  Offline
WA, USA, Tacoma
DOT 3 has a maximum cold(-40c) viscosity of 1500cSt. DOT4 a maximum of 1800cSt. DOT5.1 has a maximum cold viscosity of 900cSt.
All 3, 4, and 5.1 have a minimum hot(100c) viscosity of 1.5cSt
So a brake fluid that meets DOT4 minimum boiling temperatures and is under 1500cSt at -40c can meet both dot3 and dot4 specs.
Likewise a fluid can greatly exceed 5.1 boiling temps but due to viscosity above 900cSt it will only qualify as a DOT3/4 or if between 1500 and 1800 as a straight DOT4. (redline and amsoil racing are in this last category)
The valvoline DOT3/4 spec sheet was not proof read and does not list the product specific boiling points nor any viscosities.
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: capsicum] #4468376
07/23/17 07:29 PM
07/23/17 07:29 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Which DOT, if any, improves ABS?
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Valvoline DOT 3/4 "synthetic brake fluid? Possible [Re: SilverFusion2010] #4469001
07/24/17 01:32 PM
07/24/17 01:32 PM
Cheshire, England
barryh Offline
barryh  Offline
Cheshire, England
DOT 4+
Sometimes called super DOT 4, it has a max viscosity at -40 C of 750 cSt
I used this recently and the lower viscosity is evident at normal temperatures which makes it work well for gravity bleeding.
Barry
1979 BMW R45 (Triple QX 5W40)
2009 Mercedes C180K (Shell Helix Ultra 5W40)
