Cool, I'd love to have a filter that easy to access. as for the dish, nice touch and makes for simple clean up with a paper towl/rag.
Originally Posted By: Eddie
Maybe if you loosen the oil fill cap when you drain the oil, the filter will empty also or at least 90% of it.
I would use a pocket knife/screw driver to poke a hole in the top. This release the vacuum in the filter and allows to oil to flow through the media down the center tube. In a few mins the filter will be drained.
