2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
116 registered members (28oz, AdditiveOCD, 4WD, 14Accent, 97prizm, 87sammy, 14 invisible), 1,987 guests, and 37 spiders.
Topics295,221
Posts4,930,285
Members66,716
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Interesting: Ford Issues new 5w-20 spec (Europe) #2565609
03/12/12 07:03 PM
03/12/12 07:03 PM
Midwest
volk06 Offline OP
volk06  Offline OP
Midwest
Not sure if this should go here or in the general auto topics. I found this article interesting and wanted to share.
http://www.imakenews.com/lng/e_article002367909.cfm?x=b11,0,w
March 7, 2012
Ford Issues Engine Oil Spec
By Lisa Tocci
LONDON With the help of lubricants ally BP Castrol, Ford has created a proprietary engine oil for its innovative 1.0-liter, three-cylinder EcoBoost engine. It has begun recommending the SAE 5W-20 oil now for virtually all gasoline-fueled Fords in Europe.
This is the first time Ford has developed a new oil in conjunction with engine architecture," stated Robert Haigh of Ford in a presentation to the ICIS World Base Oils & Lubricants Conference here on Feb. 24.
The new specification, WSS M2C948 B, was activated in January. It defines an SAE 5W-20 multigrade, based largely on Europe's ACEA C2 oil sequence. However, the ACEA C2 category does not currently include a 5W-20 viscosity oil, which Ford desired for its fuel economy benefits.
Ford also found that ACEA's standard fuel economy test (the Daimler M111) was not relevant to the petite EcoBoost engine's hardware, which uses direct injection and turbocharging and delivers very high power densities. Nor was there good correlation with the ASTM Sequence VID fuel economy test used for North America's GF-5 engine oils; the VID uses a 3.6-liter V-6 engine from General Motors, he pointed out.
Hence, WSS M2C948 B contains additional requirements for in-house tests for fuel economy and piston deposit control, said Haigh, who is a senior lubricants engineer based at Ford's Dunton Technical Centre in Basildon, Essex, U.K.
Ford's 1.0-liter EcoBoost engine is a keystone in its efforts to meet fuel economy needs and stringent carbon dioxide limits, he noted. It's the latest in a turbocharged lineup that includes 1.6- and 2.0-liter models, each with four cylinders. In addition to turbocharging and direct injection, the 1.0-liter is loaded with fuel-saving technologies such as split-circuit cooling, a variable vane oil pump, variable camshaft timing and a "bespoke, optimized engine oil."
Working with BP Castrol, Ford started with a list of key attributes for the new oil specification. The oil needed to offer a fuel economy improvement of 0.9 percent over current SAE 5W-20 factory fill, and be backward compatible with Ford Sigma and I4 Duratec powertrains. "My key deliverable was that it offer no compromise on engine durability," he emphasized.
In his ICIS presentation, Haigh showed the result: a liter bottle of co-branded Ford Castrol Magnatec Professional E 5W-20 oil. The container label prominently says the oil is "For Ford EcoBoost Engines" and displays both companies' logos, with Ford's blazoned first.
Any brand of oil that meets the new specification may be used in Ford Europe's cars and warranties cannot be conditioned on using a certain brand, Haigh acknowledged, but Castrol is Ford's longtime close ally for oil development, "and Castrol is Ford's recommended supplier in Europe."
A critical part of the specification's development was creating a fuel economy test procedure. Ford researched a number of options, including friction rigs, steady-state dynamometers, transient dynamometers and chassis rolls.
Primarily, it wanted a test rig with high repeatability; a transient operation that mimicked low and high speed torque cycles as experienced in the field; accurate controls for combustion pressures and temperatures; and fast-track implementation. The test also needed to show correlation with the standard European drive cycle (NEDC) used for measuring CO2 emissions.
Secondary requirements for the fuel economy test, Haigh said, were flexibility ("We wanted to be able to test our 1.6- and 2.0-liter engines on the same facility") and manageable operating cost.
The transient dynamometer gave the broadest coverage of all these requirements, he added. It uses a full engine, has accurate controls, and can run a simplified version of the NEDC. "Fortunately, BP Castrol happened to have a transient dyno, and could make it available to us."
Ford's interval for oil changes with the new product will be 20,000 kilometers or one year, Haigh said; it may extend that to 30,000 km for commercial vehicles.
Asked whether Ford will offer the in-house fuel economy test to ACEA for inclusion in its oil sequences, he said that it's unlikely to be of interest to the group since it's tailored so narrowly to the EcoBoost's needs. "We're finding you need a specific fuel economy test for each engine," he concluded.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2565626
03/12/12 07:14 PM
03/12/12 07:14 PM
Burlington, Ontario, Canada
CATERHAM Offline
CATERHAM  Offline
That's interesting as up until now the mineral oil based 5W-20 grade has been unique the NA market.
Presumably the availability of a 5W-20 should be considerably cheaper than the 0W-20 synthetics currently dominating the European market.
-'74 Lotus Europa, 5W-50 & VSOT
-'96 BMW 328i, 50/50 TGMO 0W-20/M1 0W-40
-'94 Caterham 7, FUCHS 0W-20
-'18 Tesla Model 3 - FF diff' oil
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2565630
03/12/12 07:17 PM
03/12/12 07:17 PM
NJ
buster Offline
buster  Offline
NJ
Castrol Professional 5w20 meets the new spec.
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2565698
03/12/12 07:59 PM
03/12/12 07:59 PM
New York
pbm Online content
pbm  Online Content
New York
"Castrol is Ford's longtime close ally for oil development"
Does Conoco-Phillips (the maker of Motorcraft oils) have operations in Europe?
'Journalism is Dead'
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: pbm] #2565704
03/12/12 08:04 PM
03/12/12 08:04 PM
Midwest
volk06 Offline OP
volk06  Offline OP
Midwest
CP is the maker of motorcraft in the US
XOM is the maker of motorcraft in Canada
I think it boils down to the lowest bid but I know a few years ago ford was advertising BP fuel on their vehicles caps and OM
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2565733
03/12/12 08:26 PM
03/12/12 08:26 PM
chicago, Illinois
antiqueshell Offline
chicago, Illinois
Ford of Europe has worked with Castrol over the years.
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2565759
03/12/12 08:43 PM
03/12/12 08:43 PM
NJ
buster Offline
buster  Offline
NJ
Most likely.
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2565783
03/12/12 08:58 PM
03/12/12 08:58 PM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
"With the help of lubricants ally BP Castrol"
If this be the case wouldn't Castrol be a better product to use in Ford NA vehicles over the recommended Motorcraft brand? Whats up with this comment geez make up your mind FoMoCo. BP or CP pick one. I am guessing CP dosen't have an UK connection. Beware you thicker oil fans thin oil is going global! ontome
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: 4ever4d] #2565832
03/12/12 09:47 PM
03/12/12 09:47 PM
ID
troyh Offline
troyh  Offline
ID
Wonder if they will back spec 20 years like here?
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2566801
03/13/12 08:52 PM
03/13/12 08:52 PM
Watkins Glen, NY USA
ffracer Offline
ffracer  Offline
ConocoPhillips uses the Jet brand in Europe.
http://www.conocophillips.co.uk/EN/jetbrand/retailfuels/Pages/index.aspx
It isn't clear if C-P is making the motor oil (importing from US) or just rebranding it, as they don't have a blending plant in Europe to my knowledge.
C-P is separating its downstream (branded gasoline/oil) from its exploration business, I'm assuming Jet is part of this.
Ford, like many car companies, has different aftermarket suppliers for commodities, despite BP is a technology partner and sponsor of their World Rally Championship team.
Surprised, Ford is going to 5W-20 for Europe, given how Europeans drive their cars more spiritedly (revving) than we do in the US and have longer OCIs. Stuff must work.
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2567997
03/15/12 03:41 AM
03/15/12 03:41 AM
Australia
toyota62 Offline
toyota62  Offline
Australia
Bob.
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: toyota62] #2705509
08/05/12 10:13 AM
08/05/12 10:13 AM
Texas
modularv8 Offline
modularv8  Offline
Texas
2006 F150 5.4L
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: antiqueshell] #2705528
08/05/12 10:27 AM
08/05/12 10:27 AM
Buffalo, NY
Nickdfresh Online content
Nickdfresh  Online Content
Buffalo, NY
They've also had a relationship with BP in the US...
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: Nickdfresh] #2705546
08/05/12 10:46 AM
08/05/12 10:46 AM
North Carolina
4ever4d Offline
4ever4d  Offline
North Carolina
BP and Castrol are one and the same. Ford has been involved globally with them for several years. Seems as though it has been a profitable and good relationship.
Re: Interesting: Ford Issues new 5w-20 spec (Europe) [Re: volk06] #2705721
08/05/12 02:56 PM
08/05/12 02:56 PM
Chicago Area
mechtech2 Offline
mechtech2  Offline
Chicago Area
So is it better? Can we get it here?
Will it replace Motorcraft 5-20?
Page 1 of 3 1 2 3
