Bought Lisle external torx socket last week to prepare changing thermostat for the E430.
This morning used it to tighten the valve cover bolts the first time in 12 years, there was a little sip of oil around the valve cover gasket on both banks, the gasket is original. Many bolts were so loose, some were needed to turn more than 2 rounds and some need 1 full round.
Clean the engine and check in 2-3 weeks to see if the oil sipping around the valve cover gasket will stop.
Will check the valve cover bolts once a year from now.
