Originally Posted By: abycat
Originally Posted By: buster
Yes. I use it every 2-5k miles.
I think your on to something. Im starting to use a cleaner on my multiport versa. I tried a penzoil fuel system cleaner that was on sale. I wanted to do a techron routine regularly. But the other stuff you guys mentioned is highly praised as well. I will most likely be able to find the techron easier so i may go for that.
I think OP has to think about oil more than cleaners. Is the motorcraft syn a Low noack oil? I think if i had one of those new fords id use that stuff. Ive seen a few nice UOA's on the ford stuff. And they cant yip about wrong oil when it as a blue oval on it.
So far I've done 3 changes, all with the FL500S filter and MC Synblend 5/30. First was at 3500, then 5000 and now 10k. From 6/11 to present.
I'm wondering if I should run the tank down to about half (13g or so) and put a bottle in then or run it for the whole 26 gallons (or 23 until the low fuel light comes on).
