Is their any evidence that mixing different add pack is perfectly fine?
I cannot believe that it would make no difference what additives are used in a mix of oils, but I could well be wrong.
It might be interesting to run a mix of oils of different grades, using diffent add packs and basestocks, and then UOA a run of this strange brew after a 5K run in a car for which one has a good baseline UOA.
Could we see any difference?
I'm thinking maybe half a quart of GTX 5W-20, half a quart of Amsoil 0W-20, a quart of G-Oil 5W-30, and maybe a couple of quarts of QSUD or some other Grp III, or you could use two quarts of the G-Oil instead.
A Grp II, a Grp III, a Grp IV and a Grp V all in the same engine, with an equal diversity in add packs.
I have such a car, as well as all of these oils, but I don't think I'd waste one of my UOA kits on such an experiment.
Would be entertaining, though.
