Trying to remove the O2 sensor in my Tralblazer today and so far it will not budge. sprayed with PB blaster and let it soak in for a few hours. was getting dark so I decided to call it a night and sprayed it some more to sit over night. the socket that I hvae is a 3/8 drive and had a large slot in the side to allow the wire to go through it. are there better ones out there at Advanced auto or autozone ? the socket I am using one seems to only get a good grip where I have the least leverage . used a small 3/8 breaker bar on the socket and had a small piece of pipe on it.the way the sensor is in there there is not a lot of room for the head of a ratchet so I am not sure if a 1/2 socket and breaker bar will fit in the space.
