10k on a Wix 57356, and it has lots of issues!
by slacktide_bitog
06/24/17 06:49 PM
5.9l Dodge Magnum oil consumption question
by mbacfp
06/24/17 06:46 PM
where do you find extended shank 2'' balls?
by motor_oil_madman
06/24/17 06:32 PM
Very interesting Moog thread
by Kool1
06/24/17 05:51 PM
Napa buck a at with purchase of filer.
by Dyusik
06/24/17 05:47 PM
O'Reilly High Mileage ATF
by logcar
06/24/17 05:08 PM
Is this steelie wheel repairable? Pics
by shadow7
06/24/17 04:25 PM
Accord drain and refill question
by aquariuscsm
06/24/17 03:57 PM
Trying to diagnose a front-end clunk
by mrgrim
06/24/17 03:44 PM
Sad but funny. I really feel for the guy.
by BMWTurboDzl
06/24/17 03:37 PM
UOA of Mobil 1 EP from '05 V8 4Runner.
by JDMHero47
06/24/17 03:32 PM
How to copy video files from sd card to ipad?
by Quattro Pete
06/24/17 03:29 PM
Why DIrect Injection is really bad!
by JDMHero47
06/24/17 03:26 PM
MicroGard MGL51394 @ 6980 miles
by MrQuackers
06/24/17 03:26 PM
What vehicles will an XG8A fit?
by tc1446
06/24/17 02:44 PM
2017 BMW x3 loaner experience
by L_Sludger
06/24/17 02:24 PM
Fix for tail pipe cancer?
by Oro_O
06/24/17 02:19 PM
Energy Efficiency Report from my Utility ... :-)
by LoneRanger
06/24/17 01:50 PM
Preloading suspension before torquing - a dilemma
by Klutch9
06/24/17 01:33 PM
Acdelco air filter made in China?
by njohnson
06/24/17 12:37 PM
Italia64, donjuers, AikiBrewer, jgb3, SpaceTitan
61951 Registered Users
77 registered (2015_PSD, Al, aquariuscsm, 69GTX, 87sammy, 4 invisible), 2161 Guests and 26 Spiders online.
61951 Members
66 Forums
266988 Topics
#2546720 - 02/24/12 07:51 AM 1999 Saab coolant...flush??
Kira Offline
Loc: Champlain/Hudson Valley
Hello, This regards a 1999 Saab 9-5 2.3 (4 cyl.) with 90K. The Saab blue coolant had been changed at a dealership once before. I cleaned the reservoir bottle for fun and noticed more than superficial filming. There were patches of a thick, firm, jelly-like substance. I know the bottle is a high point where deposits can accumulate. My question is about flushing the system. I have some Prestone flush and was wondering if there's a proven product which is better. Also, What coolant can be substituted for Saab blue coolant? I will flush the system repeatedly, using every chemical known to man, if necessary, until clear. Kira
#2546956 - 02/24/12 11:58 AM Re: 1999 Saab coolant...flush?? [Re: Kira]
GoalieFergy53 Offline
Loc: Tacoma, Wa
I'm going to be doing a cooling system flush on my Saab here soon when I have a dry, "warm" day. Mine had been changed in the past when the previous owner had some engine work done and has traditional green at the moment. What I used in my previous Saab, and will put in my current one when I do my flush is Zerex G-05 coolant. It's a cheaper alternative to finding the blue G-48 coolant and works just as well. G-05 can usually be found at Napa.
As for a flush, I have an extra bottle of GM Heavy Duty Cooling System Cleaner (which I believe is one of the better ones out there, part 1#88861344), which you can get at a GM dealer for under $10. Cleaning out the reservoir is definite a good thing to do, I've heard filling it with water, liquid dish soap and putting small ball bearings or bb's in and shaking works at getting those hard to reach areas.
Make sure to check the condition of your hoses and radiator/reservior (if yours is a pressurized system) cap. Save yourself the trouble later and replace your thermostat while before your put your final fill of new coolant in. Also, do at least two rinses and use distilled water for those, that way when you put your coolant in, it'll be a ratio of coolant and distilled water (to prevent hard water scalling).
98 Saab 900S Delo400LE 5w40-NG/Wix-RL MTL
94 Chevy LLV Delo400LE 10w30-NG/Wix
97 Go-4 Interceptor Delo400LE 10w30-NG/Wix
#2552780 - 02/29/12 07:34 PM Re: 1999 Saab coolant...flush?? [Re: GoalieFergy53]
Kira Offline
Hello, I did this yesterday and feel the parallels are too many to ignore. I was prompted to clean the reservoir as the big first, motivating step. I got "labrador ears" of jelly like dirt out of it. I used coarse sand, soap, Goo-Gone, bleach, paint thinner and denatured alcohol to cut the crud. I found a bottle of Prestone flush and followed directions. Using the radiator's drain cock only, I drained out the gallon+ (which is about 60% of capacity) 8 times. The final 3 with deionized water. The blue coolant, which had been installed as part of a flush at a Saab dealership, was 4.25 years old with only 20K on it. There was no evidence of crud of any kind. There were a few bits of dirt during drain #s 4, when the fluid was clear enough to see through, and 5. I too used G-05 from a NAPA store since it's the accepted substitute, I had a sealed gallon on hand and it works in my V70 too. The only change I can feel is that the heater's temperature control is nearly instantly responsive. Raise the desired temp and the heat is delivered. Lower it and the air discharge drops fast. Now all I have to do is sell this gem of a car. Kira
Edited by Kira (02/29/12 07:36 PM)
Edit Reason: more info
