Did an oil change today on my 2008 Ford Expedition, with 37k miles on the odometer and 6k miles on the oil. Have been using Motorcraft 5w-20 synthetic blend motor oil since new. The oil level was a 1/2 quart low on the dipstick before I changed it. There is a Fumoto drain valve in lieu of the factory drain plug, so the oil drains slower with the valve than with the plug. When I pulled the drain pan from under the truck there was an oily froth on the surface of the oil. The oil itself didn't appear to be aerated, just fairly large air bubbles on top of the oil. What would cause this to happen? Does it indicate a problem with the oil or the engine? Anything to be concerned about?
