Yamaha R1 on the Autobahn
by AZjeff. 05/21/19 09:11 PM
Sea Foam question
by vavavroom. 05/21/19 08:40 PM
Study on detergent additives and abrasiveness
by addyguy. 05/21/19 08:33 PM
ST9688 oil filter on motorcycle?
by AuthorEditor. 05/21/19 05:56 PM
Circle K frustrations
by Mark72. 05/21/19 05:44 PM
Milesyn SXR, 0w20, 5,100mi, 2018 Mazda3 2.5L
by RayCJ. 05/21/19 05:42 PM
What filter are the 2AZ-FE owners using?
by 53' Stude. 05/21/19 05:28 PM
NEW TOUGH GUARD 4386 CUT OPEN
by 53' Stude. 05/21/19 05:26 PM
300v 5w40 vs Redline racing 15w40
by junkyard_sal. 05/21/19 05:25 PM
Honda 1.5T Edge 0W40 8,800mi.
by dblshock. 05/21/19 05:17 PM
Cub Cadet LTX1050VT keeps shredding mower belts
by oilpsi2high. 05/21/19 04:27 PM
What’s the best price for a set
by ShutdownCorner. 05/21/19 04:01 PM
So who uses Exxon-Mobil EHC basestocks?
by csandste. 05/21/19 03:40 PM
Thoughts on this article?
by RyanY. 05/21/19 03:27 PM
BG products any good?
by Chris B.. 05/21/19 03:22 PM
Would you rather have three cars or two?
by brages. 05/21/19 02:01 PM
Car shows had a good run.....
by rekit. 05/21/19 01:45 PM
Chinese phone scam calls have stopped?
by rekit. 05/21/19 01:39 PM
Coolant flushing
by Mad_Hatter. 05/21/19 12:44 PM
Fordpuppy, Geowebby, slugworks, tlogic, Danr42
68172 Registered Users
135 registered members (AandPDan, 4WD, 2015_PSD, 2010Civic, AC1DD, 2009Edge, 10 invisible), 2,007 guests, and 28 spiders.
Topics289,210
Posts4,964,660
Members68,172
Most Online2,967
Mar 10th, 2019
Honda MTF vs Motorcraft FML-XT-11-QDC? #2547304
02/24/12 06:10 PM
02/24/12 06:10 PM
Indiana
Funster226 Offline OP
Indiana
Need some advice here. Transmission in question is the Getrag 6 speed in the 2011 Ford Mustang.
The Motorcraft fluid is nearly $30 a quart. I can get Honda MTF for $7 or less.
However my main worry is some kind of damage that would void my warranty. I don't see any incompatibility issue from these numbers, but maybe you can?
I'm reposting INDYMAC's data on the Honda fluid since I don't have a report myself, originally posted here: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1971039&page=1
Compare:
HONDA MTF
Aluminum 0
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Moly 0
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 0
Silicon 5
Sodium 0
Calcium 3042
Magnesium 0
Phosphorus 1168
Zinc 1329
Barium 0
SUS visc at 210F 50.8
cSt visc at 100C 7.5
Flashpoint 380F
Water 0%
Insolubles 0%
TAN 3.7
AS PER MY SAMPLE SENT TO BLACKSTONE
Aluminum 0
Chromium 0
Iron 0
Copper 0
Lead 0
Tin 0
Molybdenum 4
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 4
Silicon 10
Sodium 8
Calcium 4342
Magnesium 30
Phosphorus 1492
Zinc 1308
Barium 0
SUS Viscosity @ 210 F 46.8
cSt Viscosity @100C 6.28
Flashpoint in F 405
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2547677
02/25/12 12:43 AM
02/25/12 12:43 AM
Lynchburg, Va
JasonC Offline
JasonC  Offline
Lynchburg, Va
I would stick with Motorcraft as there are no approved replacements. My 2012 Mustang GT shifts just fine and Ive driven in 25 degree weather with no problems shifting.
2012 Buick Verano 2.4
2006 Ford Mustang GT Convertible
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2547851
02/25/12 09:28 AM
02/25/12 09:28 AM
Indiana
Indiana
Did your car come from the factory with the QDC fluid or did you get it changed under the "cold shift problem" TSB that came out?
See, I have one of the first 2011's that actually shipped from the factory with the Motorcraft MTF, which is a 80w/90 fluid. It never downshifted properly and was very difficult to shift cold.
However, I can't get the car to act up when the dealership looks at it so I can't get the fluid swap for free as per the Ford TSB.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2548039
02/25/12 01:23 PM
02/25/12 01:23 PM
Indiana
Indiana
Well, I just changed over. We'll see how it shifts.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2548470
02/25/12 09:01 PM
02/25/12 09:01 PM
Indiana
Indiana
Well, I just came back from a trip around town. The MC fluid was terribly rough at first but smoothed out. I'm not sure if that's because it was so cold (23F) or because I just changed it. By the time I got home the shifting was nearly as good as the Honda fluid and head and shoulders above the factory fill.
I saved the Honda fluid, it was run for a few thousand miles, and maybe I'll send it off for analysis. The shift quality was literally butter smooth on the Honda fluid on all but the coldest mornings. But I'm worried about some kind of incompatibility on the organics. I've been told that this tranny uses paper blocker rings instead of carbon.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2548676
02/25/12 11:41 PM
02/25/12 11:41 PM
Lynchburg, Va
JasonC Offline
JasonC  Offline
Lynchburg, Va
My car was built in Oct. 11 so I am assuming it has the new fluid Ford is specing. Either way it shifts pretty smooth.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: JasonC] #2548763
02/26/12 04:28 AM
02/26/12 04:28 AM
Gonzales, La.
SwampDweller Offline
Gonzales, La.
I replaced the FF in my 2012 Mustang with Redline MTL. After reading this forum for a while and trying to digest as much as I could, I found that the Redline MTL was in between the FF and QDC in viscosity. Mine has shifted fine before and after, no difference.
I changed it , as I do on all my manual trans and rear gears, after a short run( maybe initial 5000mi) to clean out the wear in [censored].
Where does the Honda fluid fit in terms of viscosity?
From the Swamp, Lenny
16 F150 XLT 5.0 Super Crew
16 Ford Fusion SE 1.5 Turbo
14 Hustler ZTR 54 Super Duty 23/Kawasaki
Generac 20 KW 999V twin
15 Mercury 50 HP 4 Stroke
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2548767
02/26/12 05:23 AM
02/26/12 05:23 AM
Indiana
Indiana
I tried MTL and didnt like it. It felt "sticky" when hot.
The Honda fluid is only slightly heavier than the light ford fluid. The specific viscocities are listed in my charts above.
I don't remember what the viscosity of MTL is, but it's heavier than the Honda MTF.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2548930
02/26/12 10:27 AM
02/26/12 10:27 AM
Magnolia, TX
INDYMAC Offline
INDYMAC  Offline
Magnolia, TX
Here are some more Kv at 100C and TAN #'s taken from VOA's:
Honda MTF II 7.5 cSt/3.7 TAN
Amsoil MTF 9.3/2.38
BG Synchroshift 8.3/2.95
BMW MTF-LT2 7.5/0.68
BMW MTF-LT3 6.1/0.70
Elf Tranself TRJ 8.6/3.68
Ford Synthetic MTF 14.5/3.33
GMSM non-FM 9.2/3.94
Redline MTL 10.1/5.42
2013 Toyota Tundra DC 4X4 5.7L FFV
2012 Toyota 4Runner 2WD SR5
2004 Honda S2000
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: INDYMAC] #2549182
02/26/12 02:11 PM
02/26/12 02:11 PM
New Mexico
zmelli Offline
zmelli  Offline
New Mexico
The Honda is designed for use with the carbon synchronizers.
06 Acura TSX 6-Speed/GC 0W40/OEM Acura Filters
91 Honda Accord/Castrol 0W40/Micro T7316
93 Honda Accord 0W-40Edge/Micro T7316
96 Acura Integra SE
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: zmelli] #2549230
02/26/12 03:09 PM
02/26/12 03:09 PM
Indiana
Indiana
That's what I'm afraid of.
Drove a bunch of errands today. Had a slight 1-2 shift "nibble" out of the driveway but after warmed I was shifting with two fingers.
Guess I'll leave the ford stuff in for now. Hopefully I won't get the "gear whine" I've heard about after switching to the light stuff.
I also saw a rumor on another forum that there might be yet another transmission TSB released Tuesday for these cars. Here's hoping. I love my car, but it's no fun when your shifter feels like stirring coal.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2549420
02/26/12 06:39 PM
02/26/12 06:39 PM
Gonzales, La.
Gonzales, La.
Funster, just to clear things a bit. A little nibble when cold is NOT the same as shifting a bucket of coal. Mine has a little nibble here and there when cold, it is normal. I think every manual tranny I have ever driven has that. Don't try to fix the things that are normal....you can't.
I would be more concerned about the fluid being too thin and having gear whine instead. That said, it is probably fine with what you have in there now.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: SwampDweller] #2549463
02/26/12 07:18 PM
02/26/12 07:18 PM
Indiana
Indiana
Good advice. The coal comment was more about the factory fill of QS. Below 50F you flat couldn't change gears.
As far as being too thin, thats one of the points of my post. The QDC is an approved Ford fix for the bad shifting, but it's awfully thin.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: Funster226] #2549619
02/26/12 09:46 PM
02/26/12 09:46 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I would stick with the Ford MT fluid for at least 500 miles. It takes about that many miles for a new fill to get into the synchro assembly.
The AW package is fine.
Some people have done well with a 50/50 mix of the Redline MTL 70W80 and Dexron VI.
Science is about objective reality, not consensus.
Re: Honda MTF vs Motorcraft FML-XT-11-QDC? [Re: zmelli] #2549788
02/27/12 12:59 AM
02/27/12 12:59 AM
Southeast Texas
IcebergS2000 Offline
Southeast Texas
But it is still recommended for their cars that have yellow metal synchros.
The value of life can be measured by how many times your soul has been deeply stirred Soichiro Honda
