There is no adj on most carbs anymore and I wouldn't be a bit surprised if this one doesn't either..
That being said I would remove the F/F and check for fuel flow BEFORE the filter.. Your F/Line itself could be bad coming from the tank, or there could be trash in the tank blocking flow... "IF" you have good flow "BEFORE" the filter then install the F/F and check flow just past that..
If your fuel is gravity fed then this will make sure your GTG to the carb..
If your unit runs a fuel pump then you will need to connect your fuel supply to the pump and disco the line at the Carb.. Turn over the engine and check your fuel flow.. IF you have good flow then the pump is good, if not then replace the pump...
BTW, is this a SINGLE or a TWIN??
If it's a SINGLE there are no "sets" of jets.. You will most likely just have a MAIN..
Another things to check is the Fuel Solenoid.. "IF" the unit has been sitting the SOLENOID may very well be stuck closed.. Be sure check for voltage to the SOLENOID, using a Test light and turn the key on and touch the wire to the solenoid..
If you have voltage your GTG there but could still have a stuck plunger in the solenoid..
The solenoid is easy to clean so don't panic, carefully pull it apart, clean with brake wash or deap creap and reasemble.. Plug it in turn on the key and listen for the "CLICK" ofthe solenoid. There is a SPRING in there so be careful of that..
