did the drain and fill on the '07 Fusion AWD V6 today. This vehicle has the Aisin Warner F21 6 speed automatic. The drain plug was supposed to be a 10mm hex according to many but it isn't. I used a T-55 Torx socket to get mine off when the 10mm hex was too big. Here is where it drains from:
Here is the plug:
I drained into a Sterilite 1 gallon pitcher that was marked at the quart lines:
Old fluid:
drained and wiped clean:
After 3 qts and a 10oz bottle of Lubegard Red it still needed a tad.
where you need to fill it:
what I used:
Here is the plug:
Old fluid:
what I used:
