PPHM = thinner but less burn off?
by lukejo
13 minutes 16 seconds ago
Replacement Front Struts
by garageman402
15 minutes 44 seconds ago
2003 Dodge Caravan with rusty looking coolant
by Oldtom
39 minutes 40 seconds ago
Cleaning bronze bore brushes and wire brushes
by Triple_Se7en
Today at 09:10 PM
Where can I get oil sample testing done?
by FlyingTexan
Today at 08:45 PM
missing/stuck open thermostat?
by RichardS
Today at 08:43 PM
Serpentine belt on 2001 Duratec 3.0
by spk2000
Today at 08:24 PM
Pick my oil filter
by Mathew_Boss
Today at 07:56 PM
Rural King
by roadrunner1
Today at 07:50 PM
Using WMC + EyeTV One
by sleddriver
Today at 07:44 PM
Oil Change - Lubeguard Flush
by coopns
Today at 07:21 PM
Spark Plug of Choice on OPE
by chefwong
Today at 06:40 PM
no electric cars, no hydrogen cars, how about air?
by OneEyeJack
Today at 06:03 PM
My 1st LML UOA.... need input plz
by 496BB
Today at 06:02 PM
Polishing rims?
by Nissan101
Today at 05:33 PM
Hot Water Tank - Galvanic Corrosion
by larryinnewyork
Today at 05:14 PM
UOA Rotella T6 5W-40 6.0 PSD
by SqFeath
Today at 04:00 PM
Replace clutch fork?
by buck91
Today at 03:44 PM
Oil for a 2000 Chrysler LHS
by Dumc87
Today at 03:40 PM
opinon on 15w50 mobil1syn car oil in 2015 royal en
by triggercage
Today at 03:33 PM
Jetfccrew, John7109, trentreznor321, DellS, NZwogboy
60591 Registered Users
66 registered (artificialist, 901Memphis, aquariuscsm, 2004tdigls, Bandito440, andrewlg, 4 invisible), 1253 Guests and 13 Spiders online.
60591 Members
66 Forums
261343 Topics
#2541425 - 02/19/12 06:55 AM Overfilled Transfer cases..
Colt45ws Offline
Loc: Central Washington
I encounter a surprisingly large number of overfilled transfer cases. Im not talking about a trickle, either; Im talking about you pull the fill plug and it starts gluging because the level is higher than the top of the fill plug. Whats interesting is they are also almost always leaking from the rear output seal as well which you would think equals a possible low fluid condition. I mean, if you see a diff leaking its going to be low unless the owner is aware and keeps it full. No, these units seem to manage to be leaking fluid like a Detroit diesel yet be overfull. Its so common that when I see a leaking transfer case, I EXPECT to drain the fluid out to a more reasonable level rather than needing to fill it.
I have not figured out why this is, though I have a few pet theories.
1. Wizards
2. People are filling them at really odd angles (truck tipped on the nose?)
3. Its bleeding in from the transmission somehow.
The third makes the most sense to me. Its the only logical explanation, but I dont know the mechanism of how that would work. As far as I know, the rear output seal (if it was a 2WD trans) is just splash lubed, usually. I dont know why it would be any different with a t-case adapter. But, I sure Im missing something and Im way of base here.
Any other possible ideas?
-Colton
2002 Ford Crown Vic PI, 196k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#2541433 - 02/19/12 07:21 AM Re: Overfilled Transfer cases.. [Re: Colt45ws]
Michaelbgone Offline
Loc: Powhatan Virginia
I would imagine that it would likely be the case of the factory fill. I have heard from time to time of manufacturing processes that fill components while still on the component line, meaning it has not been installed/horizontal at the time of fill. The other could be fluid expansion, were the TC's cool when you checked them? Factory overfill was a common occurrence on Honda Civic manual transmissions. Other than that I can't imagine why or even how they would/could be overfilled, but it happens.
More interested in optimum than adequate-
06 Civic Si
07 Altima S 2.5 CVT
08 Kawasaki Concours 14
10 Toyota Tundra DC LTD 5.7L
96 Jeep Cherokee 4.0L
#2541448 - 02/19/12 08:00 AM Re: Overfilled Transfer cases.. [Re: Colt45ws]
Roadkingnc Offline
Loc: NC USA
It is migrating from the trans to the transfer case. I have seen it many times, the transmission output shaft seal has failed
#2541499 - 02/19/12 08:49 AM Re: Overfilled Transfer cases.. [Re: Colt45ws]
JTK Offline
Loc: Buffalo, NY
There must be not enough fluid movement in them to cause oil to come out the vent line?
That's bad because the next path of least resistance would be to blow out the seals on the T-case. Apparently those over-full ones aren't too sensitive.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2541522 - 02/19/12 09:06 AM Re: Overfilled Transfer cases.. [Re: Colt45ws]
Trav Offline
Loc: MA, Mittelfranken.de
Depending on the make and model the seal between the transmission and the transfer car can leak ATF into the transfer case.It will not backwash in the transmission just overfill the transfer case.
Almost like a leaking rear tranny seal if you will but instead of the ground it goes into the T case.
Thermal expansion is another possibility.
#2541599 - 02/19/12 10:17 AM Re: Overfilled Transfer cases.. [Re: Roadkingnc]
Chris142 Offline
Loc: apple valley, ca
x2. Verycommon on the "S" series GM trucks. Our last shop truck was so bad that we had to drain the transfercase every 4k.
If we didn't drain it then it would somehow suck atf into the vacuum lines(it had a vacuum operated TC), make lots of smoke and start running out of the HVAC controls.
02 Wrangler super-s 10w30
87 F250 proline 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric edge 5w40
