Originally Posted By: cchase
Originally Posted By: artificialist
I have dealt with people who let their plugs go over 150,000 miles. What often happens is that the ignition coil gets destroyed trying to spark across such a huge gap. By the time they have gone that far, many cars have P0420 codes because the excess fuel harmed the cat.
Sorry, this makes no sense to me. The ignition coil isn't "trying" to do anything.
It most certainly is "trying", by building voltage...
Here's the deal, reasonably new spark plugs will fire at around 7 to 10KV(thousands of volts), but the coil has the capability to build voltage to approx 25KV... Sooo if the plug hasn't fired by the time voltage reaches peak, it tried and failed... As the plugs wear the voltage required must build higher and higher till eventually it fires or the spark finds a shorter path to ground(same principal as lightning)... This shorter path is usually through the plug boot insulation or back into the coil itself, which will destroy the coil in time... The spark can also burn through the plug/coil wire(as in the 263K mi Chevy), or even through the rotor or distributor cap...
Summing up, the less voltage the coil must build, the longer your iginition components will last...
To my knowledge, ignition coils are not "smart". They do not know the gap that is being bridged with spark. I'm glad to learn more but so far this isn't making sense from an electrical standpoint. I can't find any information online about this being the case beyond internet anecdotes by mechanics (or less).
It's a fact, Jack.... I was even told this by a Federal Mogul training/tech rep during a seminar.
The greater the plug gap, the greater the juice required to jump the gap. If you go too long, you can damage the coil because it's worked too hard for too long trying to fire the ginormous gap. Basically, the coil is operating outside of it's intended parameters and will die from heat/resistance in it's windings or a fault in it's own insulation.
The remarks about failed catalysts is also correct - they suffer the (cumulative) affects of a worn ignition system in the way of misfires (hydrocarbons) or poor combustion and the resulting increase in hydrocarbons.
