Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
26 registered members (berlyn, bowtie4by, anndel, CleverUserName, Black_Thunder, 1 invisible), 754 guests, and 40 spiders.
Topics295,091
Posts4,927,656
Members66,684
Most Online2,553
Oct 27th, 2018
Equivalent or better to Amsoil Severe Gear 75W-140 #2521595
02/01/12 08:47 AM
02/01/12 08:47 AM
Kansas
backpack Offline OP
backpack  Offline OP
Kansas
Looking transmission gear oil equivalent or better than Amsoil Severe Gear 75W-140.
If there is nothing available then should I buy bottle and send it to blackstone for analysis to see if they have recommendation for equivalent or better?
Thanks advance...
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: backpack] #2521601
02/01/12 08:51 AM
02/01/12 08:51 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
IMO you cant go wrong with SVG. Sending a VOA to blackstone isnt going to get you an answer from them, and I doubt that youll be able to determine a better option by reading the VOA yourself.
What do you think is wrong with SVG that you are looking for the next best thing?
Molakule on here used to make a custom gear lube that quieted a noisy BMW diff better and longer than what I used prior (redline), and Id imagine that his stuff may be "better", but even that is subjective.
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: backpack] #2521634
02/01/12 09:26 AM
02/01/12 09:26 AM
Phoenix AZ
azsynthetic Offline
azsynthetic  Offline
Phoenix AZ
Red Line 80W-140 would be my next choice.
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: azsynthetic] #2521643
02/01/12 09:33 AM
02/01/12 09:33 AM
Wyoming
fxrider Offline
fxrider  Offline
Wyoming
Redline Shockproof 75W140 . best stuff you can get.
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: backpack] #2521673
02/01/12 10:24 AM
02/01/12 10:24 AM
Phoenix AZ
azsynthetic Offline
azsynthetic  Offline
Phoenix AZ
The Shockproof blend is not setup for high speed usage though so beware.
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: backpack] #2521679
02/01/12 10:34 AM
02/01/12 10:34 AM
Houston, TX
Solo2driver Offline
Solo2driver  Offline
Houston, TX
Severe Gear is great, use it in all of my vehicles and racecars, never had a failure.
2012 Subaru WRX AWD: RP HPS 5w-30 8K mi
2011 Mazda 2 Sport: RP XPR 0w-20 5K mi
2003 Ford Escape V6 4WD: PHM 5w-20 165K mi
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: Solo2driver] #2521865
02/01/12 01:05 PM
02/01/12 01:05 PM
Kansas
backpack Offline OP
backpack  Offline OP
Kansas
Yep I saw one oil study comparing most of the brands and Amsoil was one of the few above others.
Amsoil hard to get on these neighborhoods and I just wanted to see if there is other options available or do I bend over and get hosed with triple prices Amsoil haves.
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: backpack] #2522342
02/01/12 07:54 PM
02/01/12 07:54 PM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
Not sure where you are in KS, but you can very easily order Amsoil, and even then it's not triple the price of comparable synthetics. Also, if you are a PC you can pick up Amsoil from the Wichita, KS Distribution Center:
3800 W. 29th Street S.
Suite 5
Wichita, KS 67217
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: backpack] #4683259
03/03/18 02:21 PM
03/03/18 02:21 PM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
Reviving a thread with a question.
Based on mola, pablo, and 2015psd, I'm changing diff fluid to Amsoil SG. Readily available at Farm and Home, but what do I do if I need a limited slip additive? Amsoil recommends their branded add, I've always run RedLine additive in other gear oils. Both need to be ordered off the web.
What do the experts here say? Amsoil, RL, or commonly available LubeGard? Any significant difference?
beanoil: Tough under heat, real dirty afterwards.
Re: Equivalent or better to Amsoil Severe Gear 75W-140 [Re: azsynthetic] #4694605
03/14/18 12:08 PM
03/14/18 12:08 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Says the racers who run crazy power through 4.88 gears lap after lap ...
