Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
46 registered members (advocate, alarmguy, CapriRacer, Bandito440, 2015_PSD, Bailes1992, 3 invisible), 905 guests, and 43 spiders.
Topics290,699
Posts4,848,505
Members66,021
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Hours vs. Mileage OCI #2521537
02/01/12 08:10 AM
02/01/12 08:10 AM
New Jersey, USA
oiltard Offline OP
oiltard  Offline OP
New Jersey, USA
It seems that a lot of automotive manufacturers have abandoned the use of straight mileage as a determinant of oil life. Many (most?) newer cars come with oil life monitors that take other factors into account.
I have no way of running a complex algorithm to factor in engine tembperature or to count total engine revolutions, but what I can do is determine OCI based on total engine hours, like someone would for a piece of farm equipment.
I have an Ultragauge set up which counts this automatically, all I have to do is choose to display it. The way I figure it, the engine doesn't care if I'm cruising at 40 mph in 3rd or 55mph in 4th, but the odometer does.
So what would be the time equivalents of the old 3,000 miles OCI vs. a modern 7,500 or 10,000 OCI? What range is safe and reasonable to run an oil? And for someone who drives his car very mildly, is there a major flaw in the thought process that I might be overlooking?
2005 Honda Civic EX Coupe (Automatic)
Re: Hours vs. Mileage OCI [Re: oiltard] #2521567
02/01/12 09:08 AM
02/01/12 09:08 AM
Florida
Artem Offline
Artem  Offline
Florida
Modern OLM systems take engine operating conditions into consideration when calculating oil life. Of course someone who drives gently, maximizing MPGs will get longer oil life vs someone who drives aggressively, idles a lot in traffic, in the exact same car.
Time that the oil was in use for also matters. Racking up 10k in 5 months vs taking a year of use to do the same.
2014 Mazda 3 Hatch 2.0L & 6spd - Idemitsu 0w20 Synthetic @ $0.75 a quart. (thanks Advance Auto Parts for the awesome deal)
Re: Hours vs. Mileage OCI [Re: oiltard] #2521569
02/01/12 09:10 AM
02/01/12 09:10 AM
texas
Burt Offline
Burt  Offline
texas
Figure if you drive all highway miles, average 60 mph and change at 10,000 miles, that's 167 hours.
2011 RX350 53k miles
2015 Fiesta SFE eco-boost 25k miles
Re: Hours vs. Mileage OCI [Re: oiltard] #2521571
02/01/12 09:15 AM
02/01/12 09:15 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
Since trying to keep track of time is not practicle(after all it's just a car)10K mile OCIs has worked well for me for decades.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Hours vs. Mileage OCI [Re: oiltard] #2521573
02/01/12 09:20 AM
02/01/12 09:20 AM
Waldorf, Maryland
Corvette Owner Offline
Waldorf, Maryland
You can't set up a OLM for a car engine using just engine hours. These are often used on Marine engines, but Marine engines are usually under significant load for most of their use, unlike car engines. I believe some farm tractors also use engine hours, but again they are usually under high load.
The car engine does care if it is doing city driving verses highway driving. In city driving, you have significant acceleration from lights (higher rpms per mile) and significant idle time (little load, but not good for engine). Using total rpms (with other factors) is the way to go.
If your car does not have an OLM, then using mileage and UOAs is the way to go. Car warranties are largely based on mileage oil changes. As long as your driving style doesn't dramatically change, this is the way to go. Companies have built up a large data base centered around mileage. Also, look at the factors in the Owner's Manual to determine if your driving is Severe or Normal, as they usually have different oil change intervals.
Vehicles:
98 Corvette
06 Murano
96 Chevy Van (Custom Conversion)
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
Re: Hours vs. Mileage OCI [Re: tig1] #2521612
02/01/12 09:58 AM
02/01/12 09:58 AM
New Jersey, USA
oiltard Offline OP
oiltard  Offline OP
New Jersey, USA
It's super simple with my Ultragauge. I just watch the little screen that shows how long the engine's been running since it was last re-set. And re-set it when I change the oil.
Auto manufacturers went to OLM's because simply using mileage is a very poor indicator of how much the oil's useful life has been diminished. Hours is poor also, but I think less poor, precisely because stop & go driving is worse on the car than cruising at 55.
If I cruise at 60 for an hour (to make the numbers simple) vs. sitting in stop and go traffic for an hour and only going 10 miles, the mileage formula treats the latter as being 1/6th as much a factor in oil life usage, whereas the time formula at least treats them equally.
A perfect world (or OLM) would probably count the latter situation as more severe and adjust the remaining oil life accordingly. My point is that I'd be better served using the very simple hours figure, which counts them equally than the very simple mileage figure, which treats the former as reducing the oil life to a 6x greater degree. The example of idling vs. highway miles would represent a more extreme disparity still.
167 hours = 10 k easy miles is a good starting point for the discussion. Anybody think 150 hours on my next OCI with quality synthetic in a car that's relatively easy on oil is safe, regardless of mileage? (time won't be a factor, I'll do that in <3 months).
Thanks.
Re: Hours vs. Mileage OCI [Re: oiltard] #2521616
02/01/12 10:06 AM
02/01/12 10:06 AM
Waldorf, Maryland
Waldorf, Maryland
Thanks.
My Corvette has both gas mileage and average speed memory readings which I reset every gas fillup. My average speed is usually about 33 mph (remember idling at 0 mph severely reduces average speed) . Using this would yield 4950 miles for your oil change, I think that is low for even severe service using synthetic oil ! But to answer your question, I think it is surely safe!
Vehicles:
98 Corvette
06 Murano
14 Chevy Impala
10 Starcraft Boat
13 Buick Enclave
Re: Hours vs. Mileage OCI [Re: oiltard] #2521620
02/01/12 10:08 AM
02/01/12 10:08 AM
Midwest
volk06 Offline
volk06  Offline
Midwest
My f150 has a hour meter I reset each oci. Right now at 4400 miles I'm at 110 hours.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
Re: Hours vs. Mileage OCI [Re: oiltard] #2521678
02/01/12 11:32 AM
02/01/12 11:32 AM
TX
DrDusty86 Offline
DrDusty86  Offline
TX
For reference, my Escort has 6212 hours on it and average speed about 43mph. I change the oil at 5500-6,000 miles regardless of hours. Runs fine with zero consumption of RP.
Dusty
Re: Hours vs. Mileage OCI [Re: Corvette Owner] #2521738
02/01/12 12:22 PM
02/01/12 12:22 PM
New Jersey, USA
oiltard Offline OP
oiltard  Offline OP
New Jersey, USA
Thanks.
Yeah, sounds like it may be a bit too safe and a waste of good oil. If 167 hours represents 0 idling, 0 acceleration and deceleration for 10 k miles (an impossibility), and your average of 33 mph is more normal (~300 hours for 10 k miles), I'm thinking 225 hours is a more conservative starting point. Next OCI will start there, I'll run some UOA's and see where I end up.
Thanks.
Re: Hours vs. Mileage OCI [Re: oiltard] #2521874
02/01/12 02:12 PM
02/01/12 02:12 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
The best way would be to change oil at a certain number of gallons of gas used. This way you account for idling, cold starts, hard driving, freeway cruising... all factors basically, except time. I'm switching to this method.
1997 Maxima 181k, Edge 10w30, K&N HP-1003
2004 Corolla 191k, VWB 5w20 + SSS 10w40, MGL4967
Re: Hours vs. Mileage OCI [Re: oiltard] #2521949
02/01/12 03:17 PM
02/01/12 03:17 PM
Kansas City, MO
yesthatsteve Offline
Kansas City, MO
Thanks.
Thanks.
225 is probably a good starting point for a quality syn. 15,000 purely highway miles at an average speed of 60 is 250 hours, and pretty much any name-brand syn would do that and more in a well-maintained engine that's easy on oil.
I do about half of my miles on outer suburban roads with light traffic, speed limits between 45 and 60, and few traffic lights. The rest is pretty evenly split between interstate, regular suburban driving, and short trips, with about an hour of idling at the kids' schools each week.
My Ultragauge shows my average speed at 33.5 mph, about where I thought it would be. At 225 hours, that puts me about 7500 on an OCI, which is probably about right. Based on this discussion, I probably won't run a synthetic past 250 hrs/8500 miles in my application. I probably wouldn't take a dino past 180 hrs/6000 miles, either.
'13 LaCrosse eAssist, 50000+ miles | Magnatec 5w30 & Fram EG
'11 Accord I4 Sedan, 95000+ miles | Mobil1 0w20 & Fram EG
Re: Hours vs. Mileage OCI [Re: zorobabel] #2522016
02/01/12 04:11 PM
02/01/12 04:11 PM
Canada
vortex9 Offline
vortex9  Offline
Canada
+1 (easy when you keep a log book)
Re: Hours vs. Mileage OCI [Re: zorobabel] #2522071
02/01/12 05:09 PM
02/01/12 05:09 PM
New Jersey, USA
oiltard Offline OP
oiltard  Offline OP
New Jersey, USA
Hey, I like it. Going to think this through and try to determine how best to memorialize gallons burnt. I know I could keep mileage and mpg in the Ultragauge and then do the math myself, but there may be an even easier way.
Thanks for the great idea!
Re: Hours vs. Mileage OCI [Re: oiltard] #2522144
02/01/12 06:07 PM
02/01/12 06:07 PM
New Jersey, USA
oiltard Offline OP
oiltard  Offline OP
New Jersey, USA
The more I think about gas usage as the best single factor "OLM" I can use to determine my own OCI's, the more I like it. And the better sense it makes.
If I drive my car like heck, take short trips, and sit in traffic in the winter, I get abour 30 mpg. So 200 gallons = 6,000 miles. That's severe use. And a good syn should be ok for that interval.
If I drive it all downhill and coast as much as I can on warm days, I can approach 45 mpg. That means 9,000 miles for the same 200 gallons.
These are both extreme examples for my car and I will always fall between the two over any length of time greater than a single tank of gas. But 6-9k depending on severity of service is perfect, and tracking a nice round number of 200 gallons should be easy enough.
Thanks again to all of you.
Last edited by oiltard; 02/01/12 06:08 PM. Reason: H E Double Hockey Sticks. Sorry.
Page 1 of 3 1 2 3
