Originally Posted By: JHZR2
plus I bet you can use a coupon at AAP to get it cheaper.
You can no longer use a discount code on most of the ATF's at Advance. They change the policy a month or two ago. You can still use the coupon codes on some of the Castrol ATF's for some reason.
