Car: Oct 2003 Nissan Sentra
Engine: 1.6l 4cyl QG16DE
Car condition : Completely stock except voltage stabilizer on battery
Driving style: Gentle
Climate: Tropical, typ 25-30 deg cel, rel humid 70-90%
Oil: Carlube Triple-R 5W40 (SL/A3)
Oil in service: 4 months
Miles on Oil: 4624
Miles on engine: 29730
Oil capacity: 2.7 litre with filter change
Oil added: 0 litres
Oil Additives: none
Fuel additives: none
Oil filter: original nissan, 15208-31U00
Air filter: original viscous paper, 16546-V0100 (interval same as oil)
Sampling method: mid-stream oil from drain plug
Lab: Dyson analysis
Metals, ppm
Aluminum, Al 1
Copper, Cu 10
Chromium, Cr 0
Iron, Fe 4
Lead, Pb 2
Tin, Sn 0
Contaminants/Additives, ppm
Silicon, Si 9
Sodium, Na 2
Potassium, K 4
Phosphorus, P 758
Molybdenum, Mo 25
Magnesium, Mg 313
Calcium, Ca 1866
Zinc, Zn 1011
Sulphur, S 50
Physical Test
TBN, 4.5
Water, neg
Coolant, neg
Petrol, neg
Soot/solids, 0
Nitration, 18.5%
Oxidation, 15.5%
Vis, cSt@100deg 12.3
Miles on Oil: 4624
Oil added: 0 litres
Oil Additives: none
Lab: Dyson analysis
Metals, ppm
Aluminum, Al 1
Copper, Cu 10
Chromium, Cr 0
Iron, Fe 4
Lead, Pb 2
Tin, Sn 0
Silicon, Si 9
Sodium, Na 2
Potassium, K 4
Phosphorus, P 758
Molybdenum, Mo 25
Magnesium, Mg 313
Calcium, Ca 1866
Zinc, Zn 1011
Sulphur, S 50
Physical Test
TBN, 4.5
Water, neg
Coolant, neg
Petrol, neg
Soot/solids, 0
Nitration, 18.5%
Oxidation, 15.5%
