bitogers, I’m looking for some ideas on how to clean up a possibly sludged mini cooper s (turbo charged). This car belongs to my gf. gf followed mini’s oci and got her first oil change at 15,000 miles. The second oil change was done at 30k miles. I did the following 2 oci’s for her car. I used mobil1 5w30 and castrol edge 5w30 respectively.
I got into bitog not too long ago, and found out:
1. should have changed her ff earlier and shortened the oci (15k miles is too long)
2. The mini cooper s requires a acea a3/b3 bmw long life rated oil
3. This car consumes a lot of oil
4. From reading another forum, these cars are known for carbon buildup, b/c of direct injection
During the first 2 years of ownership, her car maintenance was covered by mini, so gf got the first 2 oil changes for free (every 15k miles or 1year). Since it was under warranty….i didn’t want to touch the car. My question is, what would be the result of these long oci’s? increased engine wear? Sludge build up?
After the 2 years were over, I started doing the oci. The first time I used mobil1 5w30, which was probably at 45k miles. the second time I used castrol edge 5w30 at 49k miles. I now know that both these oils are not acea a3/b3 rated. What damage could I have done w/ running mobil1 5w30 (which I believe is acea a1/b1) for 4k miles? the castrol edge 5w30 has only been in the car for 1k miles. she was low ½ a quart the other day, so I put in some mmo for some cleaning. After driving for a week, the car was ½ low again. this time, I topped off w/ mobil1 0w40. oil cap had thick black build up on it that i was able to wipe off. I will be dumping the current castrol edge.
My question is….how can I clean up this mess? Currently I have 10 bottles of mobil1 0w40, 3 bottles of redline 10w30 and 5 bottles of synpower 5w40. I was thinking of using 1qt of redline 10w30 and 3.5qts of mobil1 and run that for 5k oci. Do you think that is better for clean up? Or should I use some auto-rx (which I have 3 bottles) w/ synpower 5w40 and run that for 5k?
Also, since the car is known for carbon buildup, I’ve ran some seafoam though the pcv and got some crazy smoke. I’ve done the seafoam twice and she noticed better response. I just dumped a bottle of redline sl-1 in the gas tank. Once she runs the tank empty, I will change the oil.
