Gray bottle, blue label from BJs Warehouse.
Miles on oil : 10,500
Miles on Unit: 62,500
Filter Mobil 1
Grade 5w-30
"Check for source of FUEL LEAK (injectors, lines etc. Fuel is at a SIGNIFICANT LEVEL; FUEL DILUTION has caused viscosity to decrease slightly below
grade; Total Base Number is MODERATELY LOW; Infrared results indicate that NITRATION is at a MODERATE LEVEL;
(PRODUCT NAME); Lubricant and filter change acknowledged; Resample at half interval;"
Code:
Nitrate 23
Oxida 15
TBN 2.7* highlighted
Visc @ 100c 9.0
Water
Soot
Fuel 4.4* highlighted
Zinc 680
Phosphorous 581
Calcium 1970
Magnesium 8
Boron 6
Molybdenum 52
Sodium 3
Silicon 16
Copper 1
Aluminum 3
Iron 1
Don't know where the fuel is coming from. I doubt there is a leak. My first UOA, which the OCI was 15k, the fuel dilution was 3.3%. After that, I had a run of 3 OCIs with way lower fuel, so low, it was not noted on the UOAs.
Filter Mobil 1
Grade 5w-30
Code:
Nitrate 23
Oxida 15
Visc @ 100c 9.0
Water
Soot
Zinc 680
Phosphorous 581
Calcium 1970
Magnesium 8
Boron 6
Molybdenum 52
Sodium 3
Silicon 16
Copper 1
Aluminum 3
Iron 1
