1998 Chevrolet Camaro, 3800 Series II
History, In tank pump replaced 24,000k ago...and it is noisy on idle and annoying. Factory unit was whisper silent.
Only when I fill the tank, I will smell gasoline in the car and outside of it. A few miles later the idle was start racing and stall out. The stall especially happens if take the car through curve. Often the stall will occur while idling at a stop light. The car will restart easily, but I am fear stalls in precarious or in catastrophic places like in middle of the road.
The only historical code I remember is that the car has thrown some kind of EVAP code for the past few years. Before I go changing out the IAC Motor/Valve, EVAP Canister & Solenoid, etc, any guidance what this could be?
Online sources say the Solenoid Valve, EVAP hoses, and MAP sensor are culprits. Why do curves induce stalls more in this situation? Why does this only happen on full tanks?
Thanks
Thanks
