Originally Posted By: Chris142
I have a 12v automotive battery. If it got drained can I recharge it wirh a 12v Power supply? The power supply actully puts out 13.2~ volts and 5A.
I know that an actual battery charger will taper off as the battery becomes fully charged and I assume the Power supply wont?
I'm running a high power CB type of radio and the 5w power supply won't run the radio. I can use a 12v battery untill it runs down.
not sure what you are actually doing or trying to accomplish.
if you want to charge a 12 volt lead-acid car battery with a 12 volt DC power supply which is not a battery charger, then no that won't work. A car battery at full charge is 12.65 volts. And the battery at 12.25 volts open circuit voltage is down around 25% charge which is basically dead, so if you have a 12 volt power supply that puts out only 12 volts, then it would not work. Then you mention the power supply actually puts out 13.2 volts- if that is the case then it could work, however if the battery is not near full charge then the battery's internal resistance will be verty low and allow for high current flow out of the power supply, well over 5 amps, which would burn out the power supply. There is a different between "power supply" and "battery charger". A battery charger will have a current limiter in it to prevent this from happening, whereas a DC power supply most likely would not.
