Break in: Break in took a long time, as the pad material is obviously harder than the yellowstuff or my previous stoptech street performance pads. I received the pads about 2 months ago, and I put them on almost immediately. I have just finally broken them in. Keep in mind, I've broken them in with just gentle driving over the last few hundred miles. I havnt driven aggressively because of rather serious brake kidder through the steering wheel. This judder is just starting to go away and I'm starting to get a little more liberal with the pedal.
Friction: The frictional qualities are ridiculous. From cold the pad bites like OEM. But it just gets better from there. There seems to be no end to the grip from these pads.
Modulation: The pads are rock hard, and when the brakes are bled properly, the pedal is crazy hard. The brake force is strong but easy to modulate, as long as you plan on the brake force building up quickly.
Streetability: A couple minor squeals, but no big deal. You can't hear it unless the window is down. As I said cold bite is fine except for the coldest nights (40F). It only takes 1 stop to get the pedal back though.
Trackability: No time to make a canyon run yet, but I'm sure they'll take it just fine.
