Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
111 registered members (00celicagt, 1978elcamino, 830Lee, 87sammy, 14Accent, 2015_PSD, 13 invisible), 2,123 guests, and 22 spiders.
Topics306,118
Posts5,286,823
Members71,588
Page 1 of 6 1 2 6
Oil change - do you remove oil pan? #2466641 12/18/11 08:29 PM
CaveatLector Offline OP
Do you ever remove your oil pan during an oil change, just to clean out every last possible drop of old oil? If so how often?
I admit I haven't dropped an oil pan in probably 20 years, can't even remember which vehicle it was but I do remember it was easy to drop. If my current Astro wasn't so hard to drop the pan I'd do it. It bugs me that I have never dropped that oil pan to clean it out and inspect the inside...
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466646 12/18/11 08:33 PM
H
hooligan24 Offline
H
dropping the pan is not going to get all the oil out of the engine.
05 Dodge Neon SRT-4 - Mobil 1 SN 0w40
03 Nissan Xterra S/C'ed - Maxlife Blend 10w30
03 Yamaha YZF-R6 - Rotella T6 5w40
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466652 12/18/11 08:37 PM
Quattro Pete Offline
Heck no. I don't even remove the oil drain plug. smile
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466655 12/18/11 08:39 PM
Cristobal Offline
Much effort and expense for very little return. It is only reasonable if you think there is debris in that pan that might plug up the intake screen.
Surrounded by ferocious, snarling, & spoiled Poodles!
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466670 12/18/11 08:48 PM
G
GMorg Offline
G
No.
Its not like there is a filter to inspect or change like an AT.
Its not like there is something to inspect for wear like with a rear end.
Perhaps you could look for debris. However, without a really good reason, I'm not pulling a pan for a few drops of oil.
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466671 12/18/11 08:49 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Ive dropped the pan on a few cars for various reasons. Never just to get the last drops out. Never seen much of a reason, its always lean in there and the amount of remaining oil is so slight that it is insignificant.
Now if an engine was known to be sludged or abused, it may be worth it, but even still, removing the pan will not help all the nooks and crannies where oil sits.
Re: Oil change - do you remove oil pan? [Re: hooligan24] #2466673 12/18/11 08:52 PM
What was I thinking. I should have spelled it out. Meaning within the context of dropping the oil pan at an oil change, not as in disassembling the entire engine and cleaning every last drop from each part. I am talking "oil change" not "complete engine disassembly".
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466676 12/18/11 08:54 PM
But what are you trying to achieve by dropping the oil pan as part of the oil change? As has been mentioned, those last few drops of oil are meaningless considering that there is still oil in many other parts of the engine. And whatever is left is meaningless compared to the amount of fresh oil you'll be putting in.
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466677 12/18/11 08:56 PM
demarpaint Offline
Wow that's a first for me. I never knew anyone that even mentioned dropping an oil pan to get all the oil out. I've heard of people letting it drain overnight, 24 hours, pouring in a qt of oil to flush the old oil out. But dropping the pan? That's a first for me.
God Bless Our Troops
Re: Oil change - do you remove oil pan? [Re: demarpaint] #2466679 12/18/11 08:57 PM
G
Greggy_D Offline
G
I think BITOG just jumped the shark.
Greggy D.
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466690 12/18/11 09:05 PM
T
Texan4Life Offline
T
whatever floats your boat...
the only time I have removed oil pans is to replace a gasket/seal or to do rod bearings.
never found any problems. oil pickup screens were nice and clean.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466692 12/18/11 09:05 PM
Donald Online Content
Online Content
Many marine engines have their oil changed by pumping through the dipstick. That leaves maybe 1/2 QT. You do the best you can.
2015 Ford F-250 w/Powerstroke
Re: Oil change - do you remove oil pan? [Re: Greggy_D] #2466700 12/18/11 09:11 PM
9
91344George Offline
9
No reason whatsoever to do this.
A waste of time and effort.
Re: Oil change - do you remove oil pan? [Re: CaveatLector] #2466704 12/18/11 09:12 PM
sciphi Offline
Never. The only time I've dropped an oil pan is to replace a leaky gasket.
The two cars we have now would need lots of work to drop the oil pan. The Fit's is an odd shape that looks integrated into the transmission bellhousing, while the Cruze's wraps around the exhaust. About the only time I'd do it on those cars was if the pan gasket were catastrophically leaking oil or the pan itself needed to be replaced.
2013 Toyota RAV4 XLE
2012 Chevrolet Cruze Eco
Re: Oil change - do you remove oil pan? [Re: Greggy_D] #2466720 12/18/11 09:28 PM
simple_gifts Offline
haha. +1. Somehow the the oil lubricating the engine successfully minutes previously is completely invalidated when the owner decides to change it.....
2004 Prius; 131K; ATM
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Page 1 of 6 1 2 6
