01 F150 4X4, hard time dis-engaging
Originally Posted By: Schmoe
Spot on overkill, no vacuum locking hubs, a live axle that engages inside the transfer case. Both disengage and engage are handled by two solenoids located behind the battery. One is a pink hose and the other is a blue hose. The pink one is the disengagement. When it warms up, I'll take my volt meter and check for power, then check for suction. This is a common failure item on Fords. Does anyone know if that solenoid is a Ford only part? The part number from Ford is 6L3Z-9H465-A.
As I said earlier, if it is struggling to engage/disengage, new fluid MAY help! We've had zero issues with ours, which has 230,000Km on it, but I put in M1 ATF right after we bought it.
