I need options of where I go from here.
This is on a 2002 Ford Taurus with a 3.0 V6 SOHC Vulcan engine.
So my car has an issue where after a long hot run it won't start. Short trips, like to 7/11 down the street, it works fine, but if I drive home late at night. Then after that 45 minute stop-and-go drive where the engine is hot I decide to go get something to eat it wont start.
I have electricity, lights, windows, everything else works. I can hear the starter engage and it will attempt to turn the engine over. However when the starter attempts to turn the engine over the starter acts like my engine is full of jelly. The starter trys, but cannot turn the hot engine over.
I figured it was a short on the starter and decided to take it off and clean it and the connections last night. The Starter is mounted right under the oil filter and gets covered in oil every oil change and I figured that that had caused this issue.
Once I got to looking at it there was 1/4 inch thick layer of crud over some parts of the starter.
Anyways, I cleaned it up, reinstalled it and went on a drive. Highway and city to make sure everything was up to temp. When I got home I turned the car off, and then tried to restart it.
I still have the electrical problem.
My battery is only 1 year old and I have had that and my Alternator tested, by 2 different parts stores, and everything is well within spec.
Could it be my starter after 11 years is going out and only likes a well cooled car to start?
What else could it be?
Thanks!
-Dave
Thanks!
-Dave
