Originally Posted By: jmsjags
Originally Posted By: chainblu
Several years ago while doing a 'back road' road trip, I stopped at a diner for lunch. As usual I sat where I could see out a window (to keep an eye on my car). There were 3 gas stations within eyesight that featured major brand gas. I don't remember now what they were, but let's say Chevron, Shell and BP. I saw a generic tanker go from one to another until he had stopped at all three. I was like, "Well, I'll be .....!"
Another time I was at a station that was being refueled (again a generic tanker) and watched the guy as he finished his last transfer. He went to the other side of the truck and came back with a 5 gallon bucket and dumped the contents into the fill hole. I have no idea what was in that bucket, but I was thinking, "hmmmmmm.."
Maybe someone who drives a tanker or used to can enlighten us.
it's pretty much common knowledge nowadays that stations get their gas from the same distributors. the difference is the additives that each brand of gas uses. the 5 gallon bucket that you saw the worker dump into the tank was most likely the additives. just because the base stocks are the same doesn't mean the end product is.
I agree.
By the way, the only gas I have had problems with on a consistent basis is BP... In Wi, I now usually only use Shell, Kwik trip and Mobil... Used to use BP all the time. While in FL i use Chevron.
I also use a fuel cleaner every 10K to make sure the fuel system stays clean... I use Redline SL1, BG44K or Techron if I run out of the first two...
