[Cut Open] Magnefine with 23,000 miles
Texas
Well more of a unscrew than a cut open:D Anyway, I decided to go ahead and change the magnefine trans filter on our 97 caravan since I noticed some of black stuff starting to show up on the dipstick again. The filter has 22,858 miles (11 months) on it. When I originally added this filter, I also did a pan drop and replaced that filter as well.
The new filter I just swapped it in and topped off.
I was surprised how much it had accumulated. The pleats were gritty unlike any other filter I have cut open.
I'd say I got my $$ worth out it :p
http://i42.tinypic.com/rcsmj4.jpg
i was surprised how strong the magnet was. stronger than most pan magnets I have come across
http://i41.tinypic.com/2s60w0g.jpg
http://i39.tinypic.com/14o9g1u.jpg
http://i39.tinypic.com/2mmeo9u.jpg
http://i42.tinypic.com/2nvrymf.jpg
I wasn't sure if the pleat pics were gonna come out with enough detail. so I tried a new (to me) method of showing what the pleats caught. So on piece of paper I rubbed about 1/5th of the pleats around on the paper:
http://i41.tinypic.com/24edq2f.jpg
Nice photos. Did the stuff from the magnet look and feel like Neverseeze when wiped with finger? (Greasy metal).
What were the particles on the filter media? Metallic (but not Fe) or clutch material?
That filter did its job. Ive got one on my Tacoma and soon ill replace the external filter on the CRV with a magnafine as well.
Has anyone done any calculations on the increased flow restriction of adding one of these filters and if the transmission doesn't get enough (cool) fluid as a result?
It is theoretically possible that you get increased wear due to less (cool) flow.
I changed a transmission filter after 66k and it wasn't that dirty.
Ford thoroughly tested Magnefines (even installed backwards) and found a negligible drop in pressure, IIRC.
Typical in-pan filters are more like rock catchers, I read that the best ones filter up to 80 microns.
Nice thing to see a product is doing it's job. The magnet gives the Magnefine a good edge over other things. Some 51 percent of all trans contamination is ferrous and though the Magnefine fitler is only 35u, according to the engineer that designed this filter, the magnet catches some 99 percent of the ferrous particles of all sizes. For that reason, the Magnefine is somewhat more efficient than its filter media efficiency would indicate.
Was this the first run for a filter on this trans? If so, it will likely be cleaner the next time.
Does anyone know if a replacement filter cartridge is available for these? Since the top unscrews I wouldn't mind just cleaning the magnet and replacing the filter element rather than having to purchase the whole thing every time (it seems like a waste).
Yes, because Magnefine also offers an aluminum housing "performance" version that uses the same filter. Anyplace that has them should have the filters too. www.emergent.com>
The only places that have the replacement filter cartridges are charging $20 for them. I'm buying the entire filter for $15.49 so it doesn't make any sense. I figured that if I could buy the cartridge for something like $7 or $8 it would be the way to go.
Magnefine does not want the filter used again once its unscrewed.
We are talking about 1/20 of a cent per mile for the filter cost. Recycle the plastic parts.
The Magnefine filters to a nominal particle size of 30 to 35 microns.
Compared to oil filters this may not sound great, but for a transmission fluid filter it is a HUGE improvement over the best of the in-pan filters!
Also, there is a bypass valve that opens and lets the fluid flow in the unlikely event that the filter media becomes clogged.
Since you put a lot of miles on your vehicle in a short period of time AND you noticed dirt on your dipstick.....maybe changing the Magnefine every 6 months would be a good plan?
I repeat: The magnet gives the Magnefine a good edge over other things. Some 51 percent of all trans contamination is ferrous and though the Magnefine fitler is only 35u, according to the engineer that designed this filter, the magnet catches some 99 percent of the ferrous particles of all sizes. For that reason, the Magnefine is somewhat more efficient than its filter media efficiency alone would indicate.
