Oh, not so amazing. You can find other examples on the board here, DNewton and I being being only two.
I mostly use mineral oil, or a syn blend, but have used synthetic. I see no real difference in the context of the time issue.
I do believe the driving situation is the main criteria. I am rural, so anywhere I go it's usually a minimum of 20 miles from start to finish at speed of 55+, so the oil gets a chance to warm up and "cook" for a little while.
Interestingly, one of my fleet is a Honda Accord and I run it on an 8-8500 mile, no time limit schedule. That often works out to about 18 months but has almost gone two years once or twice.
Your five mile commute with a Honda is right at the cusp. If you live in a warm climate, you are not a short hopper IMO, but if you have cold winters, you are. I presume you use the car for more than commuting and a long drive every other weekend may be enough to take you out of short hopper category. The idea is to get the oil up to 160 minimum and keep it there for "a while." We have debated and researched a minimum interval for that and have not reached a consensus, nor have we found any test data. The closest we can come consensus (at least in the discussions I recall) is about a 15 minute "at temp" interval. Longer is better.
Yes, it is somewhat vehicle specific in my opinion. The oil in a small sump car will heat up much faster than in a large sump, given equal workloads. My diesel pickup hold 10 quarts and take longer to reach about 180F oil temp than the Honda that holds only five. The IH tractor, which hold 12 qts, takes even longer, partially due to the massive cooling system it has.
For a "qualified" short hopper, six month is the safe bet. The odds are good it could go a year in all but the worst situations with a good oil, but you'd want to verify that with UOA staken at 6-month intervals a few times. Once that's done, you could settle into whatever routine those tests indicated. Honestly, changing at six months is probably cheaper than the UOA route, especially if you do the maintenance yourself and price shop for your oil. Still, many of us do it just because.
