Originally Posted By: addyguy
Uuummm...I definetly wouldn't. Some of those engines are higher-revving, higher output engines (the GS-R, the IS300, and the GS 300) that may not like a 0W-20 oil.
You're engines AFAIK, all call for 30-weight oils - why not just use an Amsoil 30-weight for all of them? Buy OE 5W-30 in bulk, and you'll save some $$$.
If unsure, and if your engine calls for a 30, try RL 0W-20. It a very light 30.
If you know your engine is small OR doesnt "need" a 30, try something like Castrol Edge or just regular old good Supertech 5W-20. I dont buy Castrol Edge because Supertech exists. And on a car that isnt particularly demanding on oil (as in any car that can do well on a 20,) Supertech is fine for me.
What Toyota? Im re-reading now.
EDIT: Ok.. give ST 5W-20 on the four, RL 0W-20 on the 4runner. Id imagine the 4Runner would most need the light 30 of Redline 0W-20.
